New CRT HEI - NO START help a noob... - JeepForum.com
post #1 of 4 Old 03-10-2007, 01:28 PM Thread Starter
thedesertnomad
1983 CJ8
OK, I recently hooked up the Howell TBI to my Scrambler (258) and it would only idle for 10 min. It was recommended to go with an HEI, so I did (CRT Performance) hooked it up today and I get a whole lot of NOTHING.
I am quite a noob when it comes to engine work, I need all the help I can get.
lined up TDC on the old dizzy
It was pointing at my #1
followed all install instructions
removed old dizzy, lined up and installed new one
lined up TDC and it was pretty close to a plug (made that my #1)
followed proper order (1,5,3,6,2.4 / clockwise on the cap)
I am using the 8mm wires that came with the HEI
removed old ignition mod (used 10ga. 12V to feed the HEI)
hooked up tach wire to Howell tach position
checked my plug gaps (between .45 & .50)
I did NOT get new plugs (these are fairly new with less than an hour of time on them and look OK, some carbon)
gas getting to plugs / intermittent spark
(I hooked up a light to the #1 and get lots and lots of misses)
I measure about 9.6 volts going to the dizzy while cranking
I get about 10 volts direct at my starter
What am I doing wrong or did I miss something?!?!?
Any help would be sooooo appreciated, you guys have helped with a bunch of info so far.
thedesertnomad is offline
post #2 of 4 Old 03-10-2007, 03:55 PM
dodchall70
I am sorry I can't help you but,I just ordered my CRT HEI Thursday. Hopefully somebody responds to you soon just in case I have problems with mine.
85 CJ7, 258, Howell Fuel Injection, CRT Performance HEI Dist., 2" lift, Warn winch
Colorado Jeep Club Member #75
dodchall70 is offline
post #3 of 4 Old 03-10-2007, 05:04 PM
CJ Chet
you may not be getting enough current to the dizzy! They put out alot of fire, and therefore require alot of juice. When I installed my DUI I ran a nice FAT wire (10 gauge) from the battery through a fuse and a relay to the dizzy. No problems! According to your post, you aren't getting enough voltage. For an HEI distributor you need full alternator voltage (aprx. 14.5 for maximum RPM). If your tach is an OEM model, try disconnecting it and see what happens. WHY? John Strenk can explain it better than me!
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #4 of 4 Old 03-10-2007, 05:10 PM Thread Starter
thedesertnomad
1983 CJ8
So you are bringing it in straight from the battery with a relay tied to the ignition control power (switched power including crank)?
noob question willyb8 Jeep CJ Forum 2 07-06-2007 03:49 PM
noob Q? difference between CJ & YJ willyb8 Jeep CJ Forum 12 07-04-2007 06:56 PM
Cj Noob Info KWAG Jeep CJ Forum 10 06-09-2007 03:35 PM
jeepforum.com noob v8blazer Jeep CJ Forum 6 01-31-2006 04:08 PM
NOOB wanting a CJ nick81 Jeep CJ Forum 5 06-09-2005 11:42 PM
