new clutch adjustment problems - JeepForum.com
post #1 of 4 Old 06-26-2013, 02:03 PM Thread Starter
JBW5
1980 CJ7
i just installed a new luk clutch in my 1980 cj7. Everything work and all but my clutch pedal kinda bottoms out against the floorboard now. Like i said its driveable but a pain on take offs and obnoxious when im running through the gears. I initially set it with about an inch of play in it but it doresnt seem to matter. No matter how i adjust it it still seems to work smooth through about 3/4 push then the last /1/4 it just slams to the floor. Any tips or adjustment advice would be greatly appreciated!
JBW5 is offline
post #2 of 4 Old 06-26-2013, 02:49 PM
LumpyGrits
How much free-play do you have in the pedal?
You want about 1-1 1/4" at most.
BTW, my pedal hits the floor also....NBD
LG
LumpyGrits is offline
post #3 of 4 Old 06-29-2013, 10:27 AM Thread Starter
JBW5
1980 CJ7
Probably about an inch and its not so bad that it hits the floor but its like there is a point where there is no resistance and it just slams to the floor.
JBW5 is offline
post #4 of 4 Old 06-29-2013, 11:52 AM
LumpyGrits
CJ's clutch pedal is made to hit the floor.
"About an inch" Is it more or less than an inch? Set the free-play to no less than 1 inch and no more than 1 1/4 inch. Test drive.
Also, check the slop in the bell crank holes and down-rod from the pedal, if you run'n the OEM setup, they will wear badly into an egg shaped hole. I switched years ago to heim joints for just this reason.
LG
