New CJ7 owner needs info please - JeepForum.com
post #1 of 7 Old 04-17-2002, 08:29 PM Thread Starter
retnav94
Post New CJ7 owner needs info please
Just bought my first Jeep and I need some info on tires and gearing. I have read a few websites but am still in the dark a bit. I plan on putting a 4" suspension lift on it. I am assuming it has stock gearing. What tire size is suggested without having to redo the gearing? I plan on useing it in the winter for back and forth to work, but want to get into wheeling soon. Any advice is appreciated
Sorry if this may have double posted.
retnav94 is offline
post #2 of 7 Old 04-17-2002, 10:29 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Post
We need more info. Engine size, trans, and existing gearing. What size tire are you thinking about?
bazinga
jeepdaddy2000 is online now
post #3 of 7 Old 04-18-2002, 05:44 AM Thread Starter
retnav94
Post
I am not completely sure on the transmission or the gearing. I believe everything is stock. 258 is about all I am sure of. I would like to put 32 or 33s on it after the 4" lift. I am still in the information gathering stage so I am not set on anything. I just dont want to get too big of a tire and have a dog.
retnav94 is offline
post #4 of 7 Old 04-18-2002, 12:38 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
You probably have 3.54 gears, they were stock with manual trannies, with 4.10's as an option. Most had 3.54's. You can get away with 33's on those gears, as long as you have a low enough first gear to get you going. They won't be terrible. 4.10's would be better, tho. Checkthe tag numbers on the axles and reference them to a Factory Manual, that'll tell you waht was in them stock, just make sure they weren't swapped somewhere along the line.
4wheeler4CJ is offline
post #5 of 7 Old 04-21-2002, 07:01 PM
hollywood
Post
What year and model is your jeep? If you have at least 3:31's you can get away with 33's - however, the lower the better. Check for a tag on the front axle or a letter (letters) stamped to the right of the rear differential cover - this will tell you your axle ratios.
- Jeff
'83 cj
Another 7 by "CJ's Heaven"
hollywood is offline
post #6 of 7 Old 04-21-2002, 07:23 PM
hollywood
Post
I have four cj's, three with T-5's and one with and automatic - all came from the factory with 2:73's. Sucks to be me eh?
- Jeff
'83 cj
post #7 of 7 Old 04-22-2002, 11:26 AM
4wheeler4CJ
Arrow
Wow, holly wood, that does suck. I still have to check the axles on my '77 project. I'm getting close to getting it on the road, and will be buying some new sneakers soon. I have to see what the axles are, because I have no idea if they have been swapped out before or not.
CivilianJeep.Info Site Has It's First Info Page Up! JeepHammer Jeep CJ Forum 10 09-30-2008 02:28 PM
New CJ-7 owner bajaviking Jeep CJ Forum 10 10-04-2006 06:37 PM
New owner (in UK) paulhumphries Jeep CJ Forum 8 01-19-2006 11:03 AM
New CJ5 owner....INFO and COMMENTS. titus95 Jeep CJ Forum 0 08-26-2005 11:36 PM
New CJ-7 owner cfvol Jeep CJ Forum 4 07-08-2004 12:58 AM
