new cj7 owner - Page 2 - JeepForum.com
post #16 of 23 Old 10-04-2011, 03:06 AM
BagusJeep
1981 CJ7
If the hub is bust it is because it did not stand the strain of wheeling. Buy the WARN product, mine are quite old and are still going strong.
Before you start buying parts consider what you are going to use it for. WARN premium hubs are a no brainer for me but if you were going to turn this into a hard edged rock crawler you would be wanting something more expensive or waste your money buying twice.
Wiring is a curse but get the right wiring diagram for your year and model and study what is there. You may well find some odd wires "spliced in" for CB, radio etc. This is invariable done badly and increases the risk of fire so take out the non original wires. When you are happy with it you can tidy up the looms with tape and that plastic trunking you see around computer wires.
We can all tell horror stories about PO wiring issues. I found out last week after 3 years of wondering why the temperature gauge did not work that the PO had put a resistor in the middle of the wire under some heat shrink and just twisted the ends together. Took it out and it read fine.
My wife's Puthijeep has been completely rewired by an expert who installed a fuse box with glass fuses. When the headlights intermittently went on and off I almost tore my hair out trying to track it down as during daylight they turned on OK. Turned out a glass fuse was conducting intermittently, not blown just ..... intermittent.
Good luck with it, 1981 is the best year but only if you have a 258ci I6, paint it red and give it a proper bikini to wear to the beach.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #17 of 23 Old 10-04-2011, 03:15 AM
BagusJeep
1981 CJ7
And my wife just reminded me 1984 is also a good year but only if you paint it white, have car-pets and cushions and call it Puthijeep.
post #18 of 23 Old 10-04-2011, 10:45 AM Thread Starter
dezertnick
I went oljeep.com and didn't see a wire diagram for an 82. Is it the same as 81-83? Both of those are listed.
dezertnick is offline
post #19 of 23 Old 10-04-2011, 12:29 PM Thread Starter
dezertnick
Nevermind the I have an 82 post. Did the vin # and turns out I have a 84...
post #20 of 23 Old 10-04-2011, 12:43 PM
GlennLever
GlennLever's Avatar
Here everthing you could ever want to know about your 84 (online and free)
A-General
http://www.civilianjeep.info/84-86FSM/A-General.pdf
3,356KB file
Ba Engines General
http://www.civilianjeep.info/84-86FS...es_General.pdf
7,087KB file
Bb 150 CID 4 Cylinder Engine
http://www.civilianjeep.info/84-86FS...4_Cylinder.pdf
10,328KB file
Bc 258 CID I-6 Cylinder Engine
http://www.civilianjeep.info/84-86FS...6_Cylinder.pdf
10,530KB file
Bd Cooling & Fuel Systems
http://www.civilianjeep.info/84-86FS...el_Systems.pdf
13,924KB file
BE EGR, PVC & TAC Systems.
http://www.civilianjeep.info/84-86FS...AC_Systems.pdf
2,515KB file
Bf Fuel, Feedback & Exhaust Systems
http://www.civilianjeep.info/84-86FS...st_Systems.pdf
12.7KB file
Ca Electrical Systems
http://www.civilianjeep.info/84-86FS...al_Systems.pdf
16,159KB file
Cb Electrical Schematics
http://www.civilianjeep.info/84-86FS...Schematics.pdf
12,270KB file
D Clutch
http://www.civilianjeep.info/84-86FSM/D-Clutch.pdf
5,144KB file
E Gearboxes & Transfer Cases
http://www.civilianjeep.info/84-86FS...nsfer_Case.pdf
8,670KB file
F Automatic Transmissions
http://www.civilianjeep.info/84-86FS...ansmission.pdf
7,742KB file
Ga Steering
http://www.civilianjeep.info/84-86FSM/Ga-Steering.pdf
13,174KB file
Gb Steering, Front Axle
http://www.civilianjeep.info/84-86FS...Front_Axle.pdf
15,315KB file
H Rear Axle
http://www.civilianjeep.info/84-86FSM/H-Rear_Axle.pdf
9,086KB file
J Suspension
http://www.civilianjeep.info/84-86FSM/J-Suspension.pdf
4,763KB file
K Brake System
http://www.civilianjeep.info/84-86FS...ake_System.pdf
7,655KB file
L Heating/Air Conditioning
http://www.civilianjeep.info/84-86FS...onditoning.pdf
8,060KB file
M Accessories
http://www.civilianjeep.info/84-86FSM/M-Accessories.pdf
3,350KB file
N I.S. Notes
http://www.civilianjeep.info/84-86FSM/N-I.S._Notes.pdf
4,369KB file
O Auto Transmission Overhaul
http://www.civilianjeep.info/84-86FS...nsmissions.pdf
14,491KB file
P T-4 & T-5 Transmission Overhaul
9,372Kb / 9.15MB file
Q 4.0L & 4.2L(258 CID) Engine Overhaul
http://www.civilianjeep.info/84-86FS...4.2_Engine.pdf
10,201KB file
R '81 to '86 Jeep Parts Manual
http://www.civilianjeep.info/84-86FS...nual_81-86.pdf
37,223KB file
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #21 of 23 Old 10-04-2011, 12:44 PM
Falcon_CMH
Hey Glenn hook me up with links like that to my 1980 CJ-7 pretty please
Bought a 1980 CJ-7 that I am rebuilding ground up:
Given 6 hours to chop down a cherry tree a famous person once said I would sharpen my axe for 5 hours.
Falcon_CMH is offline
post #22 of 23 Old 10-04-2011, 01:22 PM
GlennLever
GlennLever's Avatar
Wish I could.
Personally I like paper and to that end I purchased as my first purchase a reproduction of the factory service manual1984- thru 1986 CJ-7 / Scrambler Service Manual from Bishko Automobile Literature, www.autobooksbishko.com Price was 68.50 and included shipping. The quality of the reprint is crisp and sharp with no fading.
It is well worth the money!
Glenn R. Lever
My Web Site
post #23 of 23 Old 10-04-2011, 02:55 PM Thread Starter
dezertnick
I can honestly say I am overwhelm with the flood of info...thank you very much
