New CJ10-A project - Page 7 - JeepForum.com
post #91 of 278 Old 03-16-2011, 04:26 PM
gunnar
1985 CJ10
Looking good Eric,
I am glad engine and tranny found good home.I have to say ,i am not the one who put that RTV.Probably Air force mechanics didnt have correct parts.
Keep all Jeep lovers informed with your project.
gunnar is offline
post #92 of 278 Old 03-16-2011, 04:48 PM Thread Starter
BioTex
Originally Posted by gunnar View Post
Looking good Eric,
Hey Gunnar! Good to see you on here. I knew that RTV job was not your doing. I just thought it was so funny I had to post it.
How's Germany? Many CJ's over there?
I'm pretty excited to get this tug project. I originally was just going to use the engine in a scout, but I couldn't resist a cool unique crawler.
I hope to have the cab mounted within a couple of weeks. Even if I decide to stretch the wheel base a few more inches in the back, the cab won't get in the way.
I'm planning something different for the bed. Kind of like different interchangeable beds for different situations. Like a camper or a flat bed, maybe a dump bed also. I can swap them from time to time depending on what I need at the moment. Like a full cage just for crawling. Just pop some pins maybe and lift the module off and snap on a new one.
Like attachments for bobcats...
Good to hear from you G.K.
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline
post #93 of 278 Old 03-16-2011, 05:10 PM
Balvar24
1979 CJ7
Don't 4-link set ups often have the shocks at an angle?
If you mount on an angle, won't your travel get cut down pretty significantly?
Balvar24 is offline
post #94 of 278 Old 03-18-2011, 02:15 PM
gunnar
1985 CJ10
After Texas, Germany is too cold and wet,I havent seen any CJs but there are many TJs on the post and mostly diesel JKs owned by Germans.I wonder why we dont get those in the USA.
Maybe you have already seen this but there is Toyota Land cruiser camper on expedition portal forum,it is my inspration for a Jeep Truck/Camper
I think it has 110 inches of wheelbase.Camper is permanently mounted to frame.But owner says ,if he would build similar vehicle again,build a bed/camper variation like you planned.
Here is the link:
http://www.expeditionportal.com/foru...ad.php?t=20822
Good luck with project,i cant wait to see results.
gunnar is offline
post #95 of 278 Old 03-19-2011, 09:29 PM Thread Starter
BioTex
Kind of what I'm thinking also. I'd rather build some towers, and deal with them through the bed.
BioTex is offline
post #96 of 278 Old 03-19-2011, 09:43 PM Thread Starter
BioTex
I scrounged a YJ for 5 bills yesterday, so now I have a good rust free tub for my first module. It will consist of a shortened normal tub with tailgate and I will add a roll bar/cage.
Today, I ground off the rear spring perches off the axle tubes, and reset my pinon angle so that it is 2 below the TC. This way I can get rid of the shims completely. I tack welded them in the new positions, and called it a night.
I know that I should bite the bullet, and lengthen the frame another several inches, so that I can run the stock CV shaft that was on the front of the Donor Waggy. It would save me the cost of a new DS plus it would make my YJ tub fit a whole lot better.
I'm at that point of no return, so will sleep on it some more, and decide in the AM. If I cut the back half of the YJ off just behind the doors, I can weld in a new bulkhead and that would give me the measurement of how long to lengthen the frame, or I could make the frame fit the existing DS, and make the tub fit the frame... Anyone like one way over the other?
BioTex is offline
post #97 of 278 Old 03-21-2011, 09:48 AM
CSP
Not at all. It depends on the working length of the shock whether your travel is reduced or not. You do lose the dampning effect of a shock mounting it at an angle though.
If the Waggy CV shaft is too long you don't need to go purchasing a new driveshaft. Any driveshaft shop should be able to cut that one down at a fraction of the cost of a new driveshaft.
CSP is offline
post #98 of 278 Old 03-21-2011, 09:55 AM
Balvar24
1979 CJ7
Step side beds look cool, even if they don't hold as much.
Balvar24 is offline
post #99 of 278 Old 03-21-2011, 08:43 PM Thread Starter
BioTex
I've got a machinist looking at doing just that. I live way too far to have the luxury of a drive shaft shop do it. I can have it balance later if it needs it.
As it turns out, a 2" front DS will hit the cross member, so I may have to cut in a saddle. I could go with a small OD tube, but at 35" long, the 2" would be better.
Thanks for helping.
BioTex is offline
post #100 of 278 Old 03-24-2011, 06:32 PM
Jim1611
Jim1611's Avatar
Hey Eric I was over on the Goucho thread looking around and this picture is on there. As soon as I saw it I thought of your build and the bed you're going to put on your CJ10-A. May not be exactly what you want but it does look nice.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #101 of 278 Old 03-25-2011, 08:08 AM Thread Starter
BioTex
Jim,
I saw that photo, and have to say that I don't care much for the look of the outside fenders. I prefer to keep the CJ look of the bed the same width as the cab.
I have already purchased a YJ for a donor bed. Weather or not I can bring myself to cut it up or not remains to be seen. I pick it up on Tomorrow, and will of course post some photos.
Here is Al's build over on pirate:
I really like the lines...
BioTex is offline
post #102 of 278 Old 03-25-2011, 11:12 AM
Balvar24
1979 CJ7
I'd cut the YJ tub and chalk one up for the good (CJ) guys. What did you decide on shock towers?
Balvar24 is offline
post #103 of 278 Old 03-25-2011, 12:49 PM Thread Starter
BioTex
I haven't really nailed down a solution yet. Waiting on the tub so I can make some measurements. As for the YJ, I'll know more tomorrow. Stay tuned!
BioTex is offline
post #104 of 278 Old 03-25-2011, 04:05 PM
Machinist
what are the tires he has on this awesome rig?Look like a set of muds but I cant tell what kind.
Machinist is offline
post #105 of 278 Old 03-25-2011, 04:21 PM
JoonHoss
2011 JK Wrangler
those are Goodyears, I believe the stock 'hummer' H1 tires
http://compare.ebay.com/like/3205270...=263602_309572
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
does anyone know where to find a cj10-a tug? gumbyjeep Jeep CJ Forum 7 04-21-2011 02:28 PM
CJ10 Half Top and Doors on a CJ7 81cj7id Jeep CJ Forum 4 03-13-2009 04:05 PM
CJ10 conversion cj10 Jeep CJ Forum 4 03-02-2007 09:58 AM
CJ8 vs CJ10 vs M715 monsterhangnail Jeep CJ Forum 22 02-27-2007 07:15 AM
86 CJ10 help BBCchris Jeep CJ Forum 10 12-04-2006 09:41 AM
