New CJ10-A project - Page 17 - JeepForum.com
post #241 of 278 Old 07-05-2011, 10:51 AM Thread Starter
BioTex
1979 CJ7
Originally Posted by 1x1_Speed_Craig View Post
Don't waste your money on 4.10 gears. I had 4.10s in my '10a with 34" swampers, and needed to be lower. I'd go 4.56 or 4.88 based on my experience. That Nissan SD-33 is a dog on the open road (and also at low speeds in high range).
Craig
Thanks for the advice! I'm on the fence with the 4.56 ratio because I'd like to drive the 65 miles down to the ranch. I want it to be streetable, so I'm not sure.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #242 of 278 Old 07-05-2011, 11:06 AM Thread Starter
BioTex
1979 CJ7
Originally Posted by Eaglekeeper View Post
The way the mud was sticking to the tires, must have been extra gooey.
Yes, they mine this stuff called bentonite nearby. It is a clay used to seal ponds. Not sure if this clay is bentonite, but it just keeps getting thicker and thicker.
I had chunks flying in my lap, inside my collar and down my back, hitting the inside of the windshield etc. I'm definately getting wider flares.
Currently:
BioTex is offline
post #243 of 278 Old 07-05-2011, 11:52 AM
Jim1611
Jim1611's Avatar
Eric that's some mighty nice country you have down there. If I ever get down that way I want a tour.
Hey I bet you'll be glad to get that transfer shifter going.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #244 of 278 Old 07-05-2011, 12:03 PM Thread Starter
BioTex
1979 CJ7
Man! You are so right about that! I was toolin along in 2wd, hit that snot on the road, got out and was thinking, I really don't want to crawl under this thing to shift into 4wd. Lesson learned...
Currently:
BioTex is offline
post #245 of 278 Old 07-05-2011, 01:56 PM
Balvar24
1979 CJ7
No inspection cover?
Balvar24 is offline
post #246 of 278 Old 07-05-2011, 02:16 PM Thread Starter
BioTex
1979 CJ7
I didn't think about that then, but there is enough room between the frame and body to reach in without getting underneath. Thank goodness! I was able to just bend over and reach under to shift.
Currently:
BioTex is offline
post #247 of 278 Old 07-10-2011, 01:40 PM
jcbjeep
That mud looks exactly like the mud we have down here. It aint deep but it sure is slick!
jcbjeep is offline
post #248 of 278 Old 07-11-2011, 07:25 AM Thread Starter
BioTex
1979 CJ7
Free new parts
A buddy told me i could help myself to his burned up 76 Scout Terra. It was in a garage fire, and was a total loss. I drove the 25 miles, and found the truck upside down out in a field. I pulled the axles, D30/D44. Good spares for a CJ.
I was hoping to find a T-19 manual tranny that would bolt right up to the SD33 engine flywheel adapter, but no dice. It was a 3 speed with a D20. I grabbed it anyways, along with pressure plate and clutch.
I snagged the gas tank, and the oil pan since they were still good. Not sure if I'll ever need these parts, but I know the scout II axles are getting hard to find. The disc brake setup is good.
My 4.10 gears are coming today, so plenty of work lined up.
Currently:
BioTex is offline
post #249 of 278 Old 07-11-2011, 08:18 AM
benullman
1981 CJ7
Maybe I dont know what im talking about but I thought scouts came with D44s front/rear?
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #250 of 278 Old 07-11-2011, 08:33 AM
CSP
Scouts didn't get D44s front and rear until 1974 when the Scout II came out, and Scouts had been around for several years prior to that. Scout 80s and 800s were D30 in front. Many of them also had twin stick Dana 18 transfer cases.
CSP is offline
post #251 of 278 Old 07-11-2011, 04:47 PM Thread Starter
BioTex
1979 CJ7
No, you guys know what your talking about! I took a better look at the front, and it is a D44. Not a D30. I pressure washed everything today, and the axles are mint except for one of the lockout hubs melted. Couldn't see any other damage except for the rubber brake hose burt up.
Going out now to check the ratio.
Edit: Ratio is 3.54
Currently:
BioTex is offline
post #252 of 278 Old 07-11-2011, 04:53 PM Thread Starter
BioTex
1979 CJ7
I used the transfer case shifter from the parts YJ, and adapted it to work for the CJ10. It turned out quite well, and is easy to operate. Even has the detents in the right spot, only backward. What I mean, is you have to move the shifter lateraly to shift into hi range, and should be the other way around.
Anybody know how to get the handle to fit tighter on the shifter? Seems like there must be a rubber piece that went inside the square opening? Don't really want to weld it.
Currently:
BioTex is offline
post #253 of 278 Old 07-11-2011, 06:08 PM
Skerr
This is a classic picture!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #254 of 278 Old 07-12-2011, 08:37 AM
JoonHoss
2011 JK Wrangler
...Anybody know how to get the handle to fit tighter on the shifter? Seems like there must be a rubber piece that went inside the square opening? Don't really want to weld it.
there is, it's called an isolator clip, but; the factory clips are notoriously weak, hard to find, and a tad on the expensive side.
do this instead
tack weld jam nuts to two sides of the base of the handle (like 12 and 3 o'clock) and use machine set screws to secure it. I did my T4 that way, and it worked like a charm (while not being 'permanent)
HTH
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #255 of 278 Old 07-12-2011, 10:40 AM Thread Starter
BioTex
1979 CJ7
do this instead
HTH
Hoss
Hoss,
Yeah, I was researching this very thing this AM, and saw the thread where the set screws were used. I just went ahead and ordered the original parts from QT. It was only $11 or so shipped for the clips and the isolator.
Currently:
BioTex is offline
does anyone know where to find a cj10-a tug? gumbyjeep Jeep CJ Forum 7 04-21-2011 01:28 PM
CJ10 Half Top and Doors on a CJ7 81cj7id Jeep CJ Forum 4 03-13-2009 03:05 PM
CJ10 conversion cj10 Jeep CJ Forum 4 03-02-2007 08:58 AM
CJ8 vs CJ10 vs M715 monsterhangnail Jeep CJ Forum 22 02-27-2007 06:15 AM
86 CJ10 help BBCchris Jeep CJ Forum 10 12-04-2006 08:41 AM
