New Carb.. NOT STARTING!! - JeepForum.com
post #1 of 5 Old 03-23-2003, 09:32 PM Thread Starter
cj5mudman4x4
i went through hell to get a carb that worked. Advanced Auto sold me a bad carb. and i rebuilt 2 others.. no i got a good carb. but my jeep wont start. it keeps flooding. is there something i need to know when installing a carb that i am just oblivious to? PLEASE HELP! its getting warm here in KY and my friend took the top off his YJ, i am so jealous! I WANT MY JEEP!
we drove through our malls parking lot last nite and there was a meeting of lowered trucks. i could only think of the things i could have done if i had my jeep.. as u can see i am having withdrawels!
1973 CJ5
258ci I6 rebuilt. bored .40
Painless wiring harness
INDEPENDENT OFFROAD member Bowling Green, Ky
cj5mudman4x4 is offline
post #2 of 5 Old 03-23-2003, 10:34 PM
JeepingMoose
What kind of carb? I just went through the ringer getting my carb set up in my rig also. Maybe between a few of us we can get yours up and running so you can prove to those low-rider types that the REAL action is off the road!!!!
'76 CJ7 w/'83 258 ci w/MC 2150 carb, T150, Dana 20 T-case, 30F/AMC20 rear, stock gears, 31" Armstrongs, 2.5" Skyjacker, Bestop soft top...all in all, a work in progress!
New Purchase March 2003:
1976 J20-Built 360 w/Jacobs electronics, T18 tranny, Dana 20, D44 front, D60 rear, 3.73 gears, Detroit in rear...all for $475!!!! YeeHaw!!!
JeepingMoose is offline
post #3 of 5 Old 03-24-2003, 02:28 PM
Guy Hollister
Might try the air valve thingy being jammed shut... thus starving it of air... as a first check... the oil and crap that the PCV gives to the carb helped jam mine shut some time ago... and when your in the jeep you can't tell if its opening or not... i jammed a twist tie in it... and started it ... then pulled it out... easy. But later lubed it and freed it up.
g
1984 RHD CJ7
1979 LHD CJ5
Guy Hollister is offline
post #4 of 5 Old 03-25-2003, 12:20 PM
JLCJ7
Does it have an electric or manual choke? If it is electric sometimes people forget to hook the wire back up. Also check to make sure all your linkages are hooked up... seems obvious but it happens. Then try setting the choke... If it is a NEW carb it should have no problems starting. If it is a USED, new carb there may be problems with it.....
JLCJ7 is offline
post #5 of 5 Old 03-25-2003, 08:50 PM Thread Starter
cj5mudman4x4
It is a Carter 1bbl with an electric choke.. REMANUFACTURED.. my prob. with starting was my spark plugs.. they got so drenched with gas they went bad. replaced them and now she starts.. when the engine isnt hot. i think my starter is kicking out now. it gives a wierd humming noise and wont let the engine turn over, when its hot. and when i stop for a stop sign my engine wants to die!? i am taking it to a mechanic ..
1973 CJ5
Carb return line leaking.........too much pressure? And other carb questions. Blthomas Jeep CJ Forum 0 06-01-2009 09:04 PM
Carter AFB carb issue (general carb) danheit Jeep CJ Forum 1 04-19-2009 05:34 PM
Hard Starting Carb Question silentdub Jeep CJ Forum 3 10-20-2008 09:14 AM
Starting issue after carb rebuild. (4.2L) Bobbywolf Jeep CJ Forum 5 04-26-2006 07:22 PM
new carter carb, starting problems CGrugger Jeep CJ Forum 1 07-10-2005 10:12 AM
