New Carb..New Starting issues - JeepForum.com
post #1 of 16 Old 01-29-2013, 11:27 AM Thread Starter
jtad
1980 CJ7
1980 CJ7 with a 258. Just did the "Ebay Guy" 2150 carb swap. Jeep runs great now. Starts right up in the mornings, no prob. But after you drive it for a while and get it good and warmed up, it won't restart with out just pumping the crap out of the gas. You can turn it off and restart it in 5-10 mins no prob. But wait 15-20 and it's a no go.. Wait an hour, will start right up.. Makes no senes whats the deal?
jtad is offline
post #2 of 16 Old 01-29-2013, 11:52 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Electric choke?
Matt1981CJ7 is online now
post #3 of 16 Old 01-29-2013, 01:09 PM Thread Starter
jtad
1980 CJ7
man choke.. and it doesn't make any difference if you use it or not.
jtad is offline
post #4 of 16 Old 01-29-2013, 01:14 PM
Matt1981CJ7
1981 CJ7
When it doesn't start, do you have fuel getting to the carb, and spark at the plugs?
Matt
post #5 of 16 Old 01-29-2013, 08:38 PM Thread Starter
jtad
1980 CJ7
Yes, I have tried choking it. Holding it at wide open, pump twice turn the key... nothing... just pump the crap out of it while turning it over and it will finale start.. But like I said you can turn it off and it will start right back up if it is within about 15 mins. or after 30 mins or so.. but somewhere around
the 20 min mark it will not start without all the pumping.. I have been around all kinds of cars, built hot rods, motorcycles, all kind of stuff. Never have seen anything like it.. I can't figure it out. It does it everytime. I spent all day the other day, timing the time between starts trying to figure it out.. I know it sounds stupid...But 20 mins seems to be the magic number. I guess I will just wait 30 mins and it will start right up....lol
jtad is offline
post #6 of 16 Old 01-29-2013, 08:44 PM
Matt1981CJ7
1981 CJ7
You don't understand, despite your time spent around "cars, built hot rods, motorcycles, all kind of stuff".
I repeat..is your carb getting fuel when the engine won't start.
Is you ignition getting spark to the plugs when the engine won't start?
Answer those questions, and we'll go from there.
Matt
post #7 of 16 Old 01-29-2013, 08:49 PM
BagusJeep
1981 CJ7
What fuel system have you got installed?
Have you got the 3 way filter with the tank return line installed on the 12 o'clock port? (Crucial)
When you installed this carb did you check the float levels and any inlet filter inside the carb?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 16 Old 01-29-2013, 09:08 PM Thread Starter
jtad
1980 CJ7
I do understand. I'm not trying to be smart but read my reply.... The first word I wrote was.......YES... So, I repeat...YES it is getting fuel and spark. And BagusJeep I have the three way filter, installed the proper way. Float levels good, no inlet filter in the carb.
Yesterday start the jeep and drive it to work, no problem. After work start the jeep drive home, no problem. Go home and leave about a hour later to go to sons basketball game, no problem. Watch game get ready to leave, no problem. Go to the school to pick him up after game (it was an away game). wait in the parking lot for about 20 mins for him to get there, jeep wont start without all the pumping. Leave the school stop and get gas, jeep starts right back up. Drive home, turn it off, starts right back up. try again 22 mins later, no start without pumping. Get it started, turn it off, starts right back up. Go inside come back out an hour later, no problem. This morning no problem....Matt I wan't trying to tell you I am some super mechanic by saying what I said about hot rods and motorcycles. Just trying to relay that I am not a total newbie that doesn't know jack.. It is a very strange problem I have never seen before. Wasn't looking for someone to be a smartt a** to me, just a little help. So thanks in advance for any insite anyone can lend to this.. Tad
jtad is offline
post #9 of 16 Old 01-29-2013, 11:04 PM
lucdog
1980 CJ5
The way you wrote the sentence indicates that "yes (comma) I have tried choking it."
I not a English major by any stretch. But I read it the same way as Matt1981cj7.
Make me wonder if the carb is flooding out by leaking fuel into the intake. So after 30 minutes it drys out enough to start .
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #10 of 16 Old 01-30-2013, 05:03 AM
86cj74.2L
86cj74.2L's Avatar
How about a vacuum leak at intake somewhere that opens up on heat soak when engine off and closes after a hour or so as engine starts to cool
I am using my phone so I can't see your engine. Or if its got stock exhaust manifold or a header. But the I6 is a bugger with vacuum leaks at the intake to head. Especially with regards to what type and how many gaskets your using.
86cj74.2L is offline
post #11 of 16 Old 01-30-2013, 05:51 AM
Matt1981CJ7
1981 CJ7
It sounds like a possible vapor lock to me.
Pictures of your setup would help.
Matt
post #12 of 16 Old 01-30-2013, 07:06 AM
86cj74.2L
86cj74.2L's Avatar
Matt
That's a possibility but when he replied yes to fuel I was taking it that he saw fuel squirting from accelerator pump.
Which is why he's corn fused on what's going on.
post #13 of 16 Old 01-30-2013, 07:11 AM
Matt1981CJ7
1981 CJ7
He also mentioned having to pump the throttle during the periods of hard-starting. Which leads me to delivery issues.
Matt
post #14 of 16 Old 01-30-2013, 07:59 AM Thread Starter
jtad
1980 CJ7
All new vacum lines (I know NEW doesnt spell good) but very few vacum lines, just PCV, and advance on dizy. Yes I am getting a squirt of fuel from the acc pump.. Which makes this whole having to pump it deal even stranger... Just makes no sense to me at all. Stock everything on the engine other than the Ebay Guy carb. Never had this problem before the carb change. But other than the hard start, it runs perfect. I am so confused.
jtad is offline
post #15 of 16 Old 01-30-2013, 08:21 AM
Oily
... an hour later to go to sons basketball game, ...
I see you have a son, but I am not sure how familiar you are with carburated engines. In my opinion, your restart procedure for a warm engine is wrong. Your flooding your engine. Owner's manuals used to state that to start a warm engine, to hold the accelerator pedal a quarter to half way to the floor then crank. Sitting warm will vaporize the existing fuel causing a rich effect which needs more air to lean it out. Holding it at wide open dumps a lot of fuel in an already "flooded"/rich with fuel oxygen environment. Pumping twice after that just exasperates the flooded condition.
I can't think of a good reason why pumping the crap out of it seems to work but I think it is happenstance to other conditions.
Try it again with just depressing the gas pedal a quarter of the way. If it doesn't start, quit cranking but do not let off the pedal. Try again in about 15 to 30 seconds. By the way, it is recommended not to crank longer than 15/20 second intervals to keep the starter from getting hot, eliminating premature starter failure.
Hope this helps, .
Oily is offline
