New axles for my CJ question's - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > New axles for my CJ question's
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 03-03-2014, 11:13 PM   #1
cookingguy
1979 FSJ Cherokee
So I have found a DANA 60 rear- end and a dana 44 front-end. The current spring perches are 30.5 inches apart and the perches are 3 inches wide and the front axle is 54 inches wide and the rear is 55 inches wide. Will this set up work or am going to have to change the perches and where they are mounted on the axle? If I have to change the location of the perches how do I go about figuring out where they need to be located.
cookingguy is offline   Reply With Quote Quick reply to this message
Unread 03-04-2014, 06:47 AM   #2
cookingguy
1979 FSJ Cherokee
Anybody
Unread 03-04-2014, 10:38 AM   #3
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Going off memory, I think the CJ front perches are 2" wide and 28" apart, and the rears are 2.5" wide and 36" apart. So, it sounds like you will need to remove them, cut them smaller, and re-weld them in the proper place.
I've never relocated spring perches, so I can't comment on the best way to do it. I'd probably mock everything up, with axles, springs, and driveshafts in place, then weld the perches where they need to be.
Perhaps CSP, or others with experience, will chime in with a better approach.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 03-04-2014, 02:31 PM   #4
CSP
I wish I had a nickel for every time I've answered the OP's questions.
That said I believe that the 30.5" apart isn't measured center to center and it's really 31.5" compared to a CJs 27.5"
There's no information about what the axles are out of given and there's so much information already on this site that I'm going to pull the "use the search button" card this time. Just tired of typing the same info over and over again.
CSP is offline   Reply With Quote Quick reply to this message
Unread 03-04-2014, 03:28 PM   #5
Spieg8
1984 CJ8
Not sure the OP is in the correct forum. Is the OP wanting to put these axles on a CJ (if so what model/year might be helpful), or on the 79 Cherokee listed in the profile?
Spieg8 is offline   Reply With Quote Quick reply to this message
Unread 03-04-2014, 07:55 PM   #6
cookingguy
1979 FSJ Cherokee
They are going into a 83 cj5 and are coming out of an old toyot fj not sure of the year on the fj
