New aluminum valve cover doesn't fit?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > New aluminum valve cover doesn't fit??
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 06-09-2013, 04:52 PM   #1
supersport126
I have a clearwater 4.0 conversion head and the red aluminum valve cover from Crown doesn't fit? Plus I cant tell why, at first I thought it was the rocker bridges hitting but its not. all the bolt holes look dead on it just wont sit down completely onto the head.
supersport126 is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 06:31 PM   #2
roboto65
1976 CJ5
See how the end of the valve cover is tapered down in the front is it like that in the back that taper could be the cause.
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 06:43 PM   #3
gmakra
What valve springs are you running?
It is known that some larger diameter springs interfere with the valve cover.
gmakra is online now   Reply With Quote Quick reply to this message
Unread 06-09-2013, 07:22 PM   #4
I6CJ7
My guess is the baffles for that valve cover ports (pcv and vent) hang lower and are hitting. What gasket do you have? The cork gaskets add quite a bit of height that may clearance it.
I6CJ7 is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 07:26 PM   #5
james04si
james04si's Avatar
1977 CJ5
Agree with gmakra. I have the Clearwater head with as valves and had to grind down the valve cover around a couple of the valves for it to sit correctly. There is plenty of meat on the valve cover and it just needs a little grinding to sit flush.
james04si is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 09:19 PM   #6
supersport126
It's not the ports, those I could measure. I'll try put some masking tape across the valve springs and see if I notice any marking after setting the cover back on
Unread 06-09-2013, 10:37 PM   #7
holliewood61
1981 CJ7
I gotta ask. Why do you have the bridge cut off #1
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is online now   Reply With Quote Quick reply to this message
Unread 06-10-2013, 06:17 AM   #8
supersport126
Yes its taped in the rear also
what ever springs Clearwater uses (I dont know)
Good eye, stupid me thought it was hitting the bridges so I cut one to find out......I have another on order
Unread 06-10-2013, 12:44 PM   #9
JrTjK
1978 FSJ Wagoneer
What year is the head setup? As those valve covers are said to usually only fit 93-04*ish.
JrTjK is offline   Reply With Quote Quick reply to this message
Unread 06-10-2013, 01:30 PM   #10
supersport126
Not sure what year, it's not stamped. It's whatever year Clearwater uses . Gonna mask off the inside of cover and see if I can notice where it's hitting when I get home today.
Unread 06-10-2013, 05:26 PM   #11
Nereussailor
I'd be trying to get a hold of Clearwater and ask.
I'm not sure what tomorrow will bring, but it can't be any worse than what I've already been through.
Nereussailor is offline   Reply With Quote Quick reply to this message
Unread 06-10-2013, 09:18 PM   #12
supersport126
Clearwater wouldn't even tell me what springs they used...trust me they aren't too helpful. I bought a 500 head and had to do 300 dollars worth of head work for it to work with my cam....( long story)
Unread 06-13-2013, 10:01 PM   #13
supersport126
Well got around to masking the inside of valve cover and looks like the first and last valve spring retainers are hitting. I'm gonna first file the outside where it's tight against the ARP head bolts (drivers side) and then try and carefully grind the inside a bit
Unread 06-14-2013, 07:17 AM   #14
james04si
james04si's Avatar
1977 CJ5
Sounds good. That's exactly what I did. Like I said that valve cover has plenty you can take off and as you can see it really doesn't need that much to work. I used an air die grinder and had no issues.
Unread 06-14-2013, 11:34 AM   #15
jeepwhore
Now now, we did determine part of that whole debacle was due to them not having received all the pertinent info......
As for the interference, it is a pretty well documented problem in the stroker community and came up in several google searches when I was researching cams for my head swap. So it's not specific to clearwater heads, per se.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline   Reply With Quote Quick reply to this message
