Needing a set of body mounts for a CJ any suggestions - JeepForum.com
post #1 of 9 Old 11-12-2012, 10:03 PM Thread Starter
Jevy
Hey everyone,
I did some measuring today and it looks like I'm going to be able to remove the entire body lift. That being said the existing mounts are just some 3" pucks. I do have a fiberglass tub and think it would be wise to re-install the body with some sort of a body mount. I could cut down the blocks on there now to use as a shim but I think I'ld rather do it right. Just looking for suggestions on brands or vendors to get them from? I don't know if any brand holds up than another. Any info is appreciated.
Jevy is offline
post #2 of 9 Old 11-13-2012, 08:18 AM
gpower77
I used Energy Suspension:
http://www.quadratec.com/products/26057_1X_PG.htm
You may need these too, just depends on if these are still in your existing bushings:
http://www.quadratec.com/products/55008_1000.htm
The Energy Suspension kit does not have the washers it shows in the pictures. They also offer master kits if you want to do all the leaf springs and complete bushing redo.
Garry
gpower77 is offline
post #3 of 9 Old 11-14-2012, 12:47 PM Thread Starter
Jevy
Thanks for the info!!!! I went ahead and got them ordered. Thanks again!!!!
Jevy is offline
post #4 of 9 Old 11-14-2012, 12:53 PM
CSP
Pretty sure that with a glass tub you need the puck style of mount.
CSP is offline
post #5 of 9 Old 11-14-2012, 01:17 PM Thread Starter
Jevy
I sure am glad you posted this because I was getting ready to make a big mistake. After googling it you are right it needs a rigid mount. It never occurred to me that the body would need to be rigid mounted. I was hoping to totally remove the body lift but I may take it from a 3" to 1/2"-1" or so. So I am going to remove the pucks and cut them down to the least about I think I can get away with. Man I tell you this board has a great group of people. Thanks again!!!!!
Jevy is offline
post #6 of 9 Old 11-14-2012, 04:30 PM
gpower77
Good catch CSP, didnt catch the fiberglass tub part....duh...it was written in the post!
Garry
gpower77 is offline
post #7 of 9 Old 11-14-2012, 07:08 PM Thread Starter
Jevy
thanks again guys. I asked on my build thread asking if it is possible to just mount the body directly to the frame? If I have to I'll trim them down to 1/2" or so but I'm trying to take as much of the body lift as possible. Would just bolting it direct work? Any info is appreciated.
Jevy is offline
post #8 of 9 Old 11-15-2012, 08:44 AM
CSP
You need something between the tub and frame to allow for movement. The frame flexes and you don't want that flex directly transmitted to the tub as it will crack it prematurely.
My CJ5 has the old open channel frame which flexes a LOT. I've wheeled it enough that my tub is literally coming apart. The main body mount on the drivers side under the firewall has ripped apart from the tub and I have several cracks in the tub (sheetmetal tub).
CSP is offline
post #9 of 9 Old 11-15-2012, 08:57 AM
WoodyHD
1983 CJ7
For fiberglass body you use this. You have to cut them to size. Do the four main mounts under the doors firsts to your desired height and adjust the rest to fit.
http://www.4wd.com/Jeep-Body-Parts-R...4&t_pn=MDR5000
WoodyHD is offline
