Need Your Help - JeepForum.com
post #1 of 24 Old 05-01-2013, 11:01 PM Thread Starter
DYontheForum
1981 CJ7
Need Your Help
Im in the middle of a frame off and I am bolting up the tranny and skid plate, but ran into a problem. With the skid plate on the tranny it is an inch an a half too far to the driver side, which makes me think that I put the motor mounts in wrong... There is a metal tab on the rubber mount is that supposed to be facing up or towards the ground?
Some pics would be very helpful.
DYontheForum is offline
post #2 of 24 Old 05-02-2013, 01:35 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Yes, they would. Post 'em up, let's see what you got.
Matt
Matt1981CJ7 is online now
post #3 of 24 Old 05-02-2013, 01:59 AM
John Strenk
John Strenk's Avatar
1976 CJ5
When I swapped trannies and skid plates, I thought I was about an inch and a half off also, turns out I had the skid plate mounted on the wrong holes and the hole that was off 1-1/2" wasn't even the right hole. When I finally mounted the skid plate in the correct holes, the tranny dropped right in place.
John Strenk is offline
post #4 of 24 Old 05-02-2013, 10:54 AM Thread Starter
DYontheForum
1981 CJ7
I'm think my motor mounts are in wrong.
image-4214613910.jpg   image-1701021886.jpg   image-812035850.jpg   image-2651159400.jpg   image-3826272897.jpg
post #5 of 24 Old 05-02-2013, 11:30 AM
Matt1981CJ7
1981 CJ7
I'm thinking you used the wrong set of holes, on the bottom of your trans, for the trans mount and torsion arm.
Matt
post #6 of 24 Old 05-02-2013, 11:59 AM Thread Starter
DYontheForum
1981 CJ7
The different holes would just move the tranny back or forward.
post #7 of 24 Old 05-02-2013, 12:05 PM
John Strenk
1976 CJ5
Well this certainly doesn't look right...
Forgetting about the skidplate for the moment.
Aren't there two sets of holes for the engine mount to mount to the frame?
post #8 of 24 Old 05-02-2013, 12:13 PM Thread Starter
DYontheForum
1981 CJ7
Yes but I didnt take the mounts off the frame when I did this whole project.
post #9 of 24 Old 05-02-2013, 12:26 PM
John Strenk
1976 CJ5
Could this be a PO blunder?
post #10 of 24 Old 05-02-2013, 12:40 PM Thread Starter
DYontheForum
1981 CJ7
Could be, but then everything fit fie when I took it out and now it doesn't.... I'm thinking I need to turn that rubber mount upside down, so the metal tab is pointed down.
post #11 of 24 Old 05-02-2013, 12:45 PM
Matt1981CJ7
1981 CJ7
I'm not talking the holes in the skid. I'm talking the trans mount/arm to the bottom of the trans.
Is it possible you have the rubber mount and torsion arm mounted one hole to far to one side, or the other?
Matt
post #12 of 24 Old 05-02-2013, 01:10 PM
lucdog
lucdog's Avatar
1980 CJ5
That isn't the correct torsion arm. Every one I've seen looks like this.
Or this one, on my T18
Drivers side.
Passenger side.
Both of my other V8 Jeeps look the same. With the exception of the '78, the rubber sits a little more on the frame bracket, I'm 100% sure the engine has never been out of the Jeep.
Maybe Matt will slide under his nice clean Jeep and snap a couple pics with his new iPhone.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #13 of 24 Old 05-02-2013, 01:19 PM
lucdog
lucdog's Avatar
1980 CJ5
This is on my Quadratrac Jeep.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #14 of 24 Old 05-02-2013, 01:39 PM
Matt1981CJ7
1981 CJ7
My mounts look like Bill's, only a lot cleaner.
We had 6" of freaking snow last night. It's too cold in my garage to crawl around under the Ol' Girl.
I'm sure the OPs got enough to mull over.
Matt
post #15 of 24 Old 05-02-2013, 01:43 PM
82JeepCJ7
1982 CJ7
The mounts on the engine itself look almost like FSJ (wagoneer) mounts. That might change the position of the motor (I know it makes it sit high).
If I remember correctly, the transmission is offset to the drivers side just a bit due to the transfer case. Use a level on the inside of the frame in the back, and measure over to the rear axle yolk to see if the yolk is centered or offset an inch or so. Make sure the output of the transfer case is on the same plain so you don't have a compound angle with the drive shaft.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
