Need vacuum help - not standard stuff - JeepForum.com
post #1 of 4 Old 07-14-2013, 10:59 PM Thread Starter
Dwarf
1987 YJ Wrangler
Hey gang,
I've been reading on several threads, so please don't blast me until you've seen my setup. I have a yj that the po put a 76-78 258 into. My main concern is that the engine stumbles after it gets up to temp. It starts great and idles fine, but stumbles a bit while running down the road.
I'm trying to make sense of my setup against these awesome diagrams (thanks for making these)
http://s58.photobucket.com/user/Bird...Mod-1.jpg.html
And http://home.sprynet.com/~dale02/list.htm
Here are some pictures of my setup. No computer, no stepper, no o2 sensor:
https://picasaweb.google.com/Pullen....98207762138066
Are these older versions of what became the cto?
https://picasaweb.google.com/Pullen....98084816514130
https://picasaweb.google.com/Pullen....98140862366178
Egr has nothing hooked up to it
https://picasaweb.google.com/Pullen....98276292136850
Snorkle has no vacuum valves
https://picasaweb.google.com/Pullen....98334567111218
Hanks for any pointers,
D
Dwarf is offline
post #2 of 4 Old 07-14-2013, 11:21 PM Thread Starter
Dwarf
1987 YJ Wrangler
I found this thread and will be re-hosing tomorrow.
http://www.jeepforum.com/forum/f8/po...vance-1517892/
Dwarf is offline
post #3 of 4 Old 07-15-2013, 04:02 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yeah, but those won't help you veru much with a steel manifold that has no water jacket.
These might help more.
Now you may not have all those CTO's. On my 76 I just ran the vacuum advance to the spark port. I skipped the cto to switch from manifold to poerted vacuum.
Do you know how to check your timing?
John Strenk is offline
post #4 of 4 Old 07-15-2013, 09:36 AM Thread Starter
Dwarf
1987 YJ Wrangler
Thanks a ton John. I haven't setup the timing in this one yet. I have done timing on older GMs, where I put the light on the #1 plug and used the strobe to make sure it was firing when the crank it at TDC. I assume it's a similar process on the 258. Is that right?
Dwarf is offline
