Need Tshooting advice for '82 CJ-5 with iron Duke - JeepForum.com
post #1 of 3 Old 03-23-2010, 12:56 PM Thread Starter
CeeJayFiver
1982 CJ5
Need some Troubleshooting advice: Just installed remanufactured Iron Duke using my carb, distributor, etc. When started found several vacuum leaks, replaced Carb gasket and manifold adapter gasket and it seemed to run OK but a bit rough. Discovered had canister vac and carb vent bowl lines swapped fixing that helped, but still ran rough... replaced distributor cap & rotor, smoothed out about 90%. Current problem: Idle is about 1200 RPM, and engine runs smooth, but no power - struggles to get to 45 mph! My suspicion is vacuum advance, but I apply small hand vac pump to the dist vacuum canister and it moves the base plate in the distributor just fine. The vacuum line from the Distributor is connected to the middle port of the Ported Vacuum Switch near the thermostat. I plug the line and port when setting timing, but as soon as I put the vacuum line back on the ported switch, timing goes waayy advanced and engine dies - very difficult to restart because it stays advanced. I suspect one of 3 problems: First, is the vacuum advance connected to the right source? Second, is the ported Switch bad?
or third, is my distributor sticking? Opinions? Thanks in advance! By the way its a CA Jeep so it is stock with smog gear intact...
CeeJayFiver is offline
post #2 of 3 Old 03-23-2010, 04:47 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
Time for a Jeep hammer moment....
4 cylinder CJ engines use a manifold vacuum for dist adv. The delay valve maintains vacuum advance during sudden throttle openings and the coolant is below 120 the delay valve is bypassed by the vac adv CTO when the temp is above 120.
The cto valve permits manifold vac with the delay function or without the delay function to control the distributor vac adv. When the coolant them is below 120 manifold vacuum at port 1 (top) is applied to port D (middle) a hose then supplies the dist off of port d to the dist.
When the engine temp reaches 120 the vac is ported through the delay valve directly to port 2 (closes to engine) bypassing the delay valve.
Make sure the color side of the delay valve (brown if I remember) is away from the CTO lines not toward them.
(from the manual not from me)
wow they really shrunk...
its not a lot but a good place to start to check to see if your delay valve and CTO are installed/hosed/working properly....
ex-151owner..
Mike
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #3 of 3 Old 03-23-2010, 09:34 PM
wrongway92407
wrongway92407's Avatar
Recheck your initial timing, could a tooth off!
Wrongway
My fleet:
86 CJ7 5.7 vortec. 4L60,D44's,OBA,Air tank bumpers w/D rings detroits,4.88,35" bfg, mt's 9500ti warn
86 CJ7 2.5 detroits, OBA 4.56, air tank bumpers, w/D rings,9500I warn 31x10.5x15, Trxus
86 CJ7 bone stock, w/factory 44 never seen the dirt soon to be for sale
87 Wrangler also never seen the dirt.
wrongway92407 is offline
distributor , ignition , iron duke
Iron duke to Amc 258? zwillcj5 Jeep CJ Forum 18 07-12-2012 08:47 AM
151 Iron duke Fabian15 Jeep CJ Forum 5 12-29-2011 09:13 PM
iron duke? southshore30 Jeep CJ Forum 11 02-01-2010 09:10 PM
'82 CJ7 w/151 GM Iron Duke engine Kelo Jeep CJ Forum 4 06-08-2007 03:51 PM
iron duke 151 to 6 cyl myjeep8u Jeep CJ Forum 8 01-22-2007 09:12 PM
