Need Some Locker Advice! - JeepForum.com
post #1 of 37 Old 11-02-2009, 02:57 PM Thread Starter
CJman77
1977 CJ7
Okay so I have always been passive on the locker idea. But the more I think about it, the more it makes sense. So what do I need?
I am basically trying to make a street machine with some offroad manners.
Powertrain: Chevy 350, Sm465, Dana 300
Gears are 3.31
My thought was to stick with the 3.31 gearing because with the 465 i will have about 2500 rpm at 75 with 33 inch tires.
It will probably be a 80/20 mix of Street/Offroad useage.
What do you guys suggest? How hard is it to add a locker? Will I have to do any major shimming over whats in it already?
I have read alot about the detroit truetrac as being a good preforming street locker?
Thanks for your input
Brian
CJman77 is offline
post #2 of 37 Old 11-02-2009, 03:16 PM
78treehugger
1980 CJ7
My buddy had a true trac and hates it. But some people like them. I am assuming being in FL you don't see much snow. So you could go with a lunchbox locker inthe front. Aussie, powertrax, ect. The rear should be a selectable. ARB, Ected, ect.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
post #3 of 37 Old 11-02-2009, 03:27 PM
7goldeneagle9
1979 CJ7
just get an arb. it's on its off that simple. BTW a truetrac is a limited slip and would be a good choice for you. They only fail when you would get alot less traction with one tire than the other.
7goldeneagle9 is offline
post #4 of 37 Old 11-02-2009, 03:30 PM
kickingprop
If you want to maintain normal street manners then you will want to get a selectable locker (ARB/Ox/Auburn) in the rear. That way you can turn it off when driving around on the street and it will behave as an open diff.
In the front you can throw a lunchbox (aussie/lok-rite), fullcase (detroit), or selectable in and it really wont matter in 2WD on the street with your front hubs unlocked. Full case and selectables require that you reset the gears though whereas a lunchbox drops in where the spider gears already are.
I hear good and bad about True Tracs although more good than bad.
ARB's and OX usually get the most praise on here but they are the most expensive also. A full case Detroit is actually probably the strongest but its not selectable.
I do agree with keeping your 3.31 gears with the SM465. Its got a low enough first gear that you should still have a pretty good crawl ratio offroad... I like this website for side by side comparisons on drive ratios, etc Gear Ratio Calculator
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #5 of 37 Old 11-02-2009, 04:06 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
Hmmmm a rear OX...then drop in a terra low in the 300 for like a 87:1 crawl. pick your line point and go....
Actually i had a shop do my OX beacuse i wanted a selectable and did not want to mess with the R&P set up. a lot of guys will say for the price you can regear while you are at it. i left my 3.55's in for the freeway end of the deal and love it but i wish i had a little lower gear with my axle's. you make up for that with the 465 i'm looking to do it with a 4:1
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #6 of 37 Old 11-02-2009, 05:02 PM
IDK
I went with a Ected and I can't even tell it is there on the street although I can hear it on the trails. They don't pop bang or make any noises whatsoever. Would work great in a place like Florida, works well here in Montana. A switch that you have to mount on the dash works the locker, just flip it on when you need it and when you don't shut if off.
IDK is offline
post #7 of 37 Old 11-02-2009, 07:57 PM
7goldeneagle9
1979 CJ7
dont buy OX I've seen too many issues with the cables!
post #8 of 37 Old 11-02-2009, 08:16 PM
JeepnBlake
Ox, ARB, E-Locker all CAN have problems with cables, lines, or wires, just pick your poison.
I threw a lock right up front in my cj, and personally i love it, unlock the hubs and you don't even notice.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #9 of 37 Old 11-02-2009, 08:35 PM Thread Starter
CJman77
1977 CJ7
What kind of problems? I was thinkin the OX system. Because a cable system sounds like its the least ammount of parts to fall apart.
CJman77 is offline
post #10 of 37 Old 11-02-2009, 08:35 PM
my-jeep-earl
1971 CJ5
I've had OX lockers, front and rear, in for eight years now and haven't had a problem with the cables yet.
my-jeep-earl is offline
post #11 of 37 Old 11-02-2009, 08:42 PM Thread Starter
CJman77
1977 CJ7
Okay another thought.....Since I dont offroad very much at all. Would it make any sense to just throw in a locker in the front and forgo the rear? Or would that just me stupid? Sorry I dont know all the precarious situations a locker will help in.
CJman77 is offline
post #12 of 37 Old 11-02-2009, 09:26 PM
JeepnBlake
Front Only would be just fine.
-Blake-
Build Thread:
Dad's Build Thread:
post #13 of 37 Old 11-02-2009, 09:28 PM
bentshackle
1983 CJ7
Anyone have any experience with teraflex's T-locker??
BS
bentshackle is offline
post #14 of 37 Old 11-02-2009, 09:36 PM
duffer
1955 CJ3B
With 350 in CJ DO NOT PUT a Detroit in the rear. If you have sufficient power to cause any tire slippage at all when in a turn on black top, when you ease off the power for any reason and the unit unlocks, you better have all your lane options open because you are likely going to need more than one. Could not drive the 3B with one and pulled it-put the Powerlock back in. I really miss the Detroit off road, but an ARB is going to soon take its place.
duffer is offline
post #15 of 37 Old 11-02-2009, 09:42 PM Thread Starter
CJman77
1977 CJ7
I am thinking about just doing a front wheel one and maybe keeping the rear for sometime down the road. I want to see how much offroading I end up doing before I invest 1000 bucks
CJman77 is offline
One Piece Axle-Advice for You--Advice for Me jpd1899 Jeep CJ Forum 4 12-11-2009 04:23 PM
Locker or not? TrackRat500 Jeep CJ Forum 16 06-30-2009 11:33 AM
Gears and locker advice Jeff5886 Jeep CJ Forum 13 10-06-2007 11:40 AM
Locker for AMC 20 BigYellaJeep Jeep CJ Forum 20 01-21-2006 06:53 AM
ARB Locker verses Electirc Locker. dawgates Jeep CJ Forum 10 10-04-2005 11:26 PM
