Need some axle ideas - JeepForum.com
post #1 of 6 Old 03-03-2009, 11:07 AM Thread Starter
fireman660r
I am looking to build a sand dune rig. I am thinking a cj7 or 5. I am not going to lift it much, but cut the fenders instead to keep it fairly low to the ground. I am wanting some ideas on wide axles. Real wide. Fabrication is not too big of a deal. Just wanting a good tough set of wide axles, any ideas. Thanks
fireman660r is offline
post #2 of 6 Old 03-03-2009, 11:13 AM
JeepnBlake
stock cj axles after 81 are wider, but if you want some bulletproofs chevy 14b ff and a dana 60 front.
in my case i got a matched set of axles: corp 14b ff and dana 44 with flat tops off a 74 chevy 3/4 ton they're fairly wide
but your question is still very vague
what tires do you want to run, how much horse power/what engine?
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #3 of 6 Old 03-03-2009, 11:48 AM
foggybottombob
Chevy trucks will have passenger side drops and be 69" wide. Anything from 1970 up through the 80 would probably work. I'm not familiar with newer trucks since I only visit junk yards.
foggybottombob is offline
post #4 of 6 Old 03-03-2009, 03:15 PM Thread Starter
fireman660r
junk yards and salvages is where most of the stuff will come from. The engine will most likely be a small block ford. 350 hp. 3 spd automatic or 4 speed manual. Not sure about transer case yet. This rig is going to be used almost exclusively in the sand dunes. 33" paddle tires on back and 33" terra tires up front probably. A lot of side hill playing, so I need it to be extremely stable while running sideways on a 45-50* slope. Oh, rims will be 15" wide with maximum offset. Hope this gives a little more description to what I am needing. Are Ford Dana 60's front and back pretty wide? Or are all dana's built to the same width??
post #5 of 6 Old 03-03-2009, 03:37 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The Fords will be about the same as the GM stuff..
yeah.. pretty much go with any of the full-width truck stuff... a front D44 or D60 and either a rear D60 or GM 14Bolt.
I'd decide on the transfer case first since it's going to dictate which side you're front pumpkin needs to be on.. D300 would allow a GM front axle with passenger side drop. With 33" front tires, a D44 should suffice. Maybe build it with alloy shafts and drive flanges for strength..
BESRK is offline
post #6 of 6 Old 03-04-2009, 08:16 AM Thread Starter
fireman660r
So, ideally if I could come up with a matched t-case and front and rear axles from same rig I would be set up good then?
AMC 20 axle replacement. I'm looking for ideas. cowdodger1 Jeep CJ Forum 13 01-24-2010 11:03 PM
major axle problem, any ideas on what to replace? stompjrkz400 Jeep CJ Forum 0 12-11-2009 03:32 PM
SPARE Axle Storage Ideas.... any other ideas? Fjguercio Jeep CJ Forum 3 12-10-2009 08:54 AM
SHARE IDEAS!! Need custom exhaust ideas for Chevy 350 Turbo! DWK213 Jeep CJ Forum 3 04-18-2009 08:57 PM
Narrowtrack rear axle with 2" spacers match up with a widetrack front axle? Blthomas Jeep CJ Forum 1 05-11-2007 08:25 PM
