Need new radiator: OEM style, or Aluminum? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Need new radiator: OEM style, or Aluminum?
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wdMarch Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 04-06-2015, 11:11 AM   #1
Colt44
Colt44's Avatar
1983 CJ7
This is continued fromthis thread.:
As a result of the above, my 30-year-old radiator has been tested and found wanting. Leaks and corrosion, etc.
The decision now comes down to:
A) Have the original radiator re-cored with a new three-row core.
B) Chuck the oem setup and move to a modern style aluminum radiator.
Opinions, suggestions, experiences?
"We are all in the gutter, but some of us are looking at the stars."
~ Oscar Wilde via Chrissie Hynde
Colt44 is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 11:22 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Aluminium can't be trail fixed. I had mine recored and it worked well. I asked for 3 core, but the shop said the newer style 2 core will perform the same and run 25% cooler.
Be sure your tanks aren't too thin though. I torqued mine up and tore off an end strap and it took a little piece of tank with it. My frame is cracked with no back cross members left so the free standing rad got stressed.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 01:34 PM   #3
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I would get the existing unit re-worked, or buy a new standard copper and brass replacement in order to keep the Jeep closer to stock. One problem you may find is that I think the copper and brass units are becoming more expensive and aluminum becomes the cheaper and more common metal for radiators. This is happening with heater cores. Copper is becoming more expensive, and of course brass is an alloy containing copper.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 02:24 PM   #4
ADDZ71
1979 CJ7
I replaced mine with a Autozone version and it was of same general quality as the version I took out. Metal body etc. I think it was under $200.
ADDZ71 is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 03:11 PM   #5
WindKnot
WindKnot's Avatar
1977 CJ7
I would re-core if I could rather than install an aluminum replacement. As mentioned, they CAN be repaired on the trail. Also, note the info you gave about a 30 year old radiator is a pretty good testament in itself.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration? http://www.jeepforum.com/forum/f8/ph...ation-1807257/
WindKnot is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 04:21 PM   #6
Colt44
Colt44's Avatar
1983 CJ7
Decided to go with a re-core. The shop can do a new 3-row core for not much more than I could get an O-A from Q-Tec, etc. so it just makes sense to go that route.
Not really too excited about grafting in the fancy-schmancy aluminum unit, plus sensor, plus fan/shroud, plus wiring.
If this was for a street vehicle where I didn't have to worry about frame/chassis flex, trail damage, etc. I might go for the shiny new tech.
But the price plus complexity leads me back to the KISS principle. And my CJ retains its vintage look by keeping the "original" radiator that came with it from Toledo.
Thanks for the advice!
Unread 04-06-2015, 04:51 PM   #7
turbogus
1978 CJ5
Location: Albany~town, Oregon, Oregon my home and for 200 billion slugs
I stuck with copper/brass on account of all the text I've read about this material makes for better heat exchange than aluminum. Granted aluminum radiators are lighter, but for my 360 I prefer copper/brass
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 05:43 PM   #8
y2k-fxst
1964 CJ6
While copper and brass are a better heat exchanger than aluminum, the tubes and fins have to be soldered together with lead that has a low heat exchange value. This unfortunately means that the efficiency of the copper/brass is reduced. The aluminum is actually welded using the same material as the core and fins, this allows it to actually be more efficient than the soldered copper/brass. At least that is what I've been told by my brother with 30+ years working at Modine.
I own a JEEP and a Harley, and some people still can't figure out why I'm always broke!
y2k-fxst is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 09:26 PM   #9
jeep_boy02
1980 CJ7
X2 ^
If you can't find an OEM quality replacement don't let just anyone recore it. If they aren't a reputable place they will try to pull one over on you... Do not accept a radiator with "fitted" together tanks or plastic tanks. I had a place "recore" mine and picked it up only to find their main method was to use a universal core and fit to match "close" to original plastic tanks. I was pissed!
jeep_boy02 is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 10:08 PM   #10
CSP
Aluminum radiators get their efficiency from surface area. There are a LOT more tubes and fins in an aluminum radiator due to the fact that it is lighter. A copper/brass radiator would weight a metric crap ton if one had as many tubes/fins as an aluminum radiator. The more tubes/fins, the greater area there is for heat exchange with the air.
CSP is online now   Reply With Quote Quick reply to this message
Unread 04-07-2015, 01:30 AM   #11
EgulAye
EgulAye's Avatar
1980 CJ5
I can't fault your choice either. I blew my old radiator a few months ago and went with a new copper / brass direct replacement from Summit. In my case the radiator was in really bad shape. The direct replacement fits just like the factory original and I didn't have to mess around at all to get things installed. I also agree with the idea of keeping the work local and re-using existing materials. Good luck with the repair!
1980 CJ5
1987 YJ
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline   Reply With Quote Quick reply to this message
Unread 04-07-2015, 04:32 AM   #12
AFRd_CJ5
1976 CJ5
Just an FYI, and no disrespect on your decision at all, but.. an aluminum radiator isn't just for a "street vehicle". I run an aluminum unit in mine, and I'd bet my Jeep has seen as much or more chassis flex than most (and continues to do so).
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline   Reply With Quote Quick reply to this message
Unread 04-07-2015, 06:59 AM   #13
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm a bit confused over this statement.
There's no difference in the install or functionality of a aluminum radiator. They bolt up just like the original, only they are a lot lighter and easier to work with. No wires or sensors involved.
Matt
Matt1981CJ7 is online now   Reply With Quote Quick reply to this message
Unread 04-07-2015, 07:54 AM   #14
turbogus
1978 CJ5
I did not mean to stir the pot, sorry about my mistaken opinion. That being said, I'll take the word that aluminum radiators are superior. I'm dubious about pulling my fully functional brass copper rad for an aluminum unless there is a failure though.
Unread 04-07-2015, 07:59 AM   #15
WindKnot
WindKnot's Avatar
1977 CJ7
Copper vs aluminum radiators has been debated here ad nauseum, Each side brings up their own "facts" every time.
