need a new radiator - JeepForum.com
post #1 of 9 Old 06-03-2012, 11:25 AM Thread Starter
BamaLonghorn
1980 CJ7
need a new radiator
Any suggestions for a new radiator? I don't want to spend a ton of money on it.
Originally Posted by sparkchaser View Post
You must be new here. A good 90% of arguments on Jeep Forum are built on gross generalizations and a framework of logical fallacies that fall apart under the slightest bit of scrutiny.
2001 Jeep Wrangler Sport - SOLD
1979 Jeep CJ-5 - Sold
1980 Jeep CJ-7
BamaLonghorn is offline
post #2 of 9 Old 06-03-2012, 11:40 AM
mvigo
mvigo's Avatar
before you spend any $$ on a more than likely cheap chinese POS, take your old one to a reliable radiator shop and see if they can fix it. The old, original radiators, when fixed, are much better then any POS you will buy new and you know they will fit!
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #3 of 9 Old 06-03-2012, 05:11 PM
GlennLever
GlennLever's Avatar
http://www.jeepforum.com/forum/f8/cj...l#post12262955
RockAuto offers three Spectra ratiators
SPECTRA PREMIUM Part # CU583 15-7/8" Between Tanks; Heavy Duty Cooling $186.79
SPECTRA PREMIUM Part # CU58 16-3/4" Between Tanks $220.79
SPECTRA PREMIUM Part # CU80315-5/8" Between Tanks; Standard Duty Cooling $237.70
The inlets and outlets and cap are right where they should be, the lower outlet is angled up as it should be.
The one in the Jeep has 15 5/8 between the tanks but is a three row. The three row spectra is 15 7/8. (The core width is correct)
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #4 of 9 Old 06-03-2012, 11:00 PM
james04si
james04si's Avatar
1977 CJ5
Yup go with the rock auto spectre cu583. It's a good 3 core for a great price. I have had mine for a year and no issues. Was a bit cheaper then. I picked it up for about $150 plus shipping at the time. I think if you want to get one from a local store autozone has the same thing.
james04si is offline
post #5 of 9 Old 06-03-2012, 11:08 PM
benullman
1981 CJ7
not so fast. Go to Autozone and get one. Spectra 3 core is $180 with a lifetime warranty. If you ever have ANY issue, take it back..
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #6 of 9 Old 06-04-2012, 08:46 AM
Jawbox
Just for comparison, I brought my old radiator to the shop and they repaired it for about $100.
Jawbox is offline
post #7 of 9 Old 06-04-2012, 08:50 AM
Baldum
1984 CJ8
Yea, good luck finding someone who will work on a radiator for a decent price. I had no luck in my area.
I took the opportunity to get a three core instead of the two when I replaced mine.
Baldum is offline
post #8 of 9 Old 06-04-2012, 10:30 AM
james04si
james04si's Avatar
1977 CJ5
Good deal but most places want to charge an arm and a leg compared to these prices to rebuild one when I tried to do that on my 64 Impala. Patching a leak might be a bit cheaper but you still would have the same old core.
post #9 of 9 Old 06-04-2012, 11:27 AM
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
Get the Spectra. Whether you use Rockauto or a local store they are top quality radiators and you wont be disappointed. They produce for the oem's as well. We received a new International radiator at work the other day and Navistar's label was stuck over the Spectra label!
'85 CJ-7 Laredo currently under construction.
BlkCJ7Laredo is offline
A solution / gap between radiator and grill / no room between radiator and fan GlennLever Jeep CJ Forum 6 10-25-2011 11:03 AM
Radiator Fitment / Gap between radiator and front grill GlennLever Jeep CJ Forum 23 10-24-2011 08:07 PM
Radiator Hoses for AMC 360 to CJ Radiator Rollbar Jeep CJ Forum 2 04-18-2009 11:45 AM
Do I need a Chevy Radiator or a Jeep Radiator? brice1310 Jeep CJ Forum 8 04-19-2007 07:46 PM
Radiator cdoemel Jeep CJ Forum 2 08-20-2005 02:25 PM
