Need a new Dash Pad... - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Need a new Dash Pad...
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 11-03-2005, 11:21 AM   #1
CJ5_Fan
1980 CJ5
I am currently installing a front cage into my CJ5 and since I have a non-vented window dash pad, I am told I will need to replace it with one that is made for jeeps with hard doors and crank windows so it will allow for the bar to come down the side of the windshield.
I have not been able to find a OEM or replacement dash that specifies this. I find some that say that they work with vented windows, but they appear to be the same as the other ones.
Does anybody have a link to one of the 'short' dash pads or even a part number?
I really appreciate the help. If I can't locate one, then I will have to cut up my stock one... anybody done that? (if so, how well did it come out and how did you seal up the cut end?)
Thx......
1980 CJ5 Renegade with 304 v8
Click HERE to check out my CJ5 restoration project page
CJ5_Fan is offline   Reply With Quote
Unread 11-03-2005, 11:54 AM   #2
dawgates
1980 CJ7
I have to say that I have never seen two different dash pads, but you never know what Jeep had for an option.
I had to remove my dash pad to install my front cage loop. I have seen some Jeep that had the ends off, then the pad recovered. I didn't install the defroster defectors either. So far so good, but it doesn't get that cold here in Southern Nevada.
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline   Reply With Quote
Unread 11-03-2005, 12:01 PM   #3
Hibbitz
I know that there are the two different dash options. I was scratching my head when I got my CJ7 and it had fly windows (crank windows) and they can't open b/c the dash is right there. I was then looking in the Quadratech catalog and saw the two different dash options.
That said.............................. I think it is just the overlay and not the full dash but if anyone knows where you can get them... I might have to step up once all the "other" stuff get finished.
KLH
Hibbitz is offline   Reply With Quote
Unread 11-03-2005, 12:03 PM   #4
John Strenk
John Strenk's Avatar
1976 CJ5
This is for vent windows
Notice the end is relieved on the ends. The other pad is strait across to the ends.
http://www.4wd.com/shop/productdetai...60458&model=tj
John Strenk is offline   Reply With Quote
