Need Major Help - JeepForum.com
post #1 of 15 Old 01-28-2007, 05:09 PM Thread Starter
Cheever1804
1979 CJ7
Need Major Help
Okay, so it's snowing here and my Camaro does not like it at all. I have a 1979 Cj7 Jeep, with the V8 304. I recently broke my axle and i just got that fixed. Well in the process of my axle being fixed my distributor Rusted up. so i went ahead and replaced the Distributor, Plugs, Wires, Coil, Distributor Cap, and Rotor. and it still wont fire. I have Gas, Spark, and i even tried to spray starting fluid in it. I timed it. and it Perfect. Still nothing. what am i Over Looking.
P.s. My buddy said something about the Egr Valve being bad. Could this be the prob?
1979 Cj7, Amc 304, Quadratrac, Skyjacker 4" lift, 33" Super Swamper Boggers.
Cheever1804 is offline
post #2 of 15 Old 01-28-2007, 05:10 PM
Fropleyqk
Fropleyqk's Avatar
Well, you've got fuel and spark. Is there frozen moisture on your air filter? Have you tried starting it without the filter on? Just a thought.
Fropleyqk is offline
post #3 of 15 Old 01-28-2007, 05:15 PM Thread Starter
Cheever1804
1979 CJ7
Yep, Tried it without the Air Filter, and With it. Still nothing.
post #4 of 15 Old 01-28-2007, 05:27 PM
redcj576
1979 CJ7
something like that happened to me.couple of my friends and i was wheeling and my jeep suddenly stopped.We checked everything Gas, Spark,Distributor, Plugs, Wires,battery and everything is ok.i tried lots of times no fire.we decided to trail it to home.while we were trailing i tried once again and the Jeep started.nothing happened since.
try moving your jeep .Just a thought
CJ5 Project finally finished...
'77 CJ7 -.GM 305,T176,4.10s,37x14.5 Creepy Crawlers
'79 CJ7- 350,TH400,NP205,4.88s,39.5" Creepy Crawlers
'61 Chevy Apache 10-all stock
'90 Chevy K1500 4x4 Truck-LT265/75R16 BFG All terrains
redcj576 is offline
post #5 of 15 Old 01-28-2007, 06:32 PM
ClarkGriswold
ClarkGriswold's Avatar
Have you checked to see that you're getting fire to the plugs? If I read your post correctly, you've tried starter fluid also and it won't fire. ....not even for a little?
"That's nothing to be proud of Rusty. .....fifty yards." - Clark Griswold
Red Jeep Club #488
ClarkGriswold is offline
post #6 of 15 Old 01-28-2007, 06:34 PM
Bard
I would check your fuse and also wires, coil, soleniod, etc, could be deadset, which is if it isn't run alot, parts go bad at times. If you have a test light, check the wires.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #7 of 15 Old 01-28-2007, 07:21 PM
Shameless Elmer
83 CJ5
1983 CJ5
Are you sure you have the distributor in right? i.e. rotor pointed at the correct tit on te distributor?
Is the distributor possibly 180* off?
How did you time it without the engine running?
Shameless Elmer is offline
post #8 of 15 Old 01-28-2007, 07:35 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
[QUOTE=Cheever1804]I timed it. and it Perfect.
QUOTE]
I'd hate to say it but they are famous last words..
was the engine rotated wile the dizzy was out?..Check to make sure your getting fire at the plugs..Look over all connections to the dizzy,and coil..Was it a a brand new dizzy?
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #9 of 15 Old 01-28-2007, 07:39 PM
John N
1981 CJ8
How long has it been sitting? Has the fuel gone bad? Try a new fuel filter and fresh gas. Also, might need a new fuel pump, if it's been sitting a while too.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #10 of 15 Old 01-28-2007, 08:07 PM Thread Starter
Cheever1804
1979 CJ7
Okay, I went ahead and re timed it. I went a ahead and rotated the engine one time without the distributor. I went ahead and Tdc the engine. Put the Dizzy back in, and not it sounds like it wants to fire now. So I will call it a night and start fresh tomorrow, due to it's now 9:00 pm and really cold out side. Please just keep giving me Idea's to try just encase this does not work. Thanks for all the help so far.
P.s. It sat about 1 month without running, Checked all the plugs with a test light. It was a Reman Dizzy. Gas is about 1 month old, I can see the Fuel going into the Carb.
post #11 of 15 Old 01-28-2007, 08:35 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
a good tip is to put a cork in the spark plug hole..When you turn it over to tdc on the Compression stroke<<<this is key<<<the cork will pop out as compresion is being built in the #1 cylinder..or a buddys finger works also..
:hahaha: yj
post #12 of 15 Old 01-28-2007, 09:23 PM
No_Bs
1977 CJ5
Originally Posted by scrambeled
a good tip is to put a cork in the spark plug hole..When you turn it over to tdc on the Compression stroke<<<this is key<<<the cork will pop out as compression is being built in the #1 cylinder..or a buddys finger works also..
Finger does not always work, despite of the fact that it should. My "magic 258 start up routine" is to switch all the wires, and it works every time. Don't ask. Anyway, make sure you are not 180 out, then have a buddy turn the dizzy while you are cranking to see if it helps, it probably will.
No_Bs is offline
post #13 of 15 Old 01-28-2007, 10:06 PM
Shameless Elmer
83 CJ5
1983 CJ5
If it is firing now and sounds like it wants to start, but also sounds like the timing is way off and won't allow it to run, which is what the above posters are getting at, just lift the distributor out enough to disengage the distributor gear from the camshaft gear and rotate the shaft of the distributor 180*, or 1/2 of a full rotation, and stick the distributor back in. That should get it to where it will run.
Then, you can time it exactly.
This is just another method to accomplish the same thing the others are saying.
post #14 of 15 Old 01-28-2007, 10:08 PM
tscuda
Have you checked the gap for the stator and pick up? Is there a rotor in there? Dont laugh I seen that b4.
tscuda is offline
post #15 of 15 Old 01-29-2007, 08:13 AM
BIG REED
1977 CJ7
you might double check your firing order.
sounds stupid but ive seen people go the wrong way around their dist. with wires w/out thinking about it and that will only fire on #1.
just something easy to double check and eleminate as a possibility.
'77 CJ-7, AMC 360, t-18a, soa
BIG REED is offline
Major Damage? trueprimitive Jeep CJ Forum 8 07-19-2009 09:44 PM
Major PITA SavSilvrCJ Jeep CJ Forum 5 09-01-2007 01:13 PM
A major setback?? TetanusCJ7 Jeep CJ Forum 10 08-01-2007 08:18 AM
major problem with my CJ weldmaster4000 Jeep CJ Forum 3 06-14-2006 10:08 AM
Major backfire!!! merch_boy Jeep CJ Forum 3 04-30-2004 07:38 PM
