Need a little help with dual battery instal - Page 2 - JeepForum.com
post #16 of 23 Old 02-03-2013, 05:34 PM
turbogus
1978 CJ5
On 'Black Betty' I used a Stinger SGP 32 unit, much like a dandified starter relay I think but the wiring instructions were straighforward enough even for a dimwhit like me
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #17 of 23 Old 02-03-2013, 05:50 PM
248107
Guest
1983 CJ7
I seen your solenoids weren't the Ford style.What was wrong with them.They had the same terminals,go figure huh
248107 is offline
post #18 of 23 Old 02-03-2013, 06:28 PM
chooster5000
1981 CJ7
the reason I deleted my fuse is that when I got the jeep someone hooked it up wrong and actually had the solenoid powered all the time or some weird *** thing and the fuse port was bad anyway
1981 jeep cj-7 258 with t-176 4 speed and 31x10.5x15 tires,
1979 jeep cj-5 gone but not forgotten
chooster5000 is offline
post #19 of 23 Old 02-04-2013, 05:08 AM Thread Starter
Galt
Galt's Avatar
1983 CJ7
I believe they sent me continuous duty solenoids.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
1993 RX7 1.3L Rotary/ GT40R turbo/484 rwhp
2002 F-150 Lariat 5.4L V8
2007 GMC Yukon Denali 6.2L V8
Galt is offline
post #20 of 23 Old 02-04-2013, 05:28 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Galt,
FYI, an alternative to your double solenoid setup would be a high-torque starter with it own solenoid. It would certainly simplify your wiring, and probably give as much, or more, starting power.
Here's the starter I was talking about earlier that wouldn't work when wired in series with the factory solenoid.
Matt
Matt1981CJ7 is offline
post #21 of 23 Old 02-06-2013, 05:16 PM Thread Starter
Galt
Galt's Avatar
1983 CJ7
Hey Matt,
Thanks for the link. i may consider that when my current starter ****s out on me.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
Galt is offline
post #22 of 23 Old 02-07-2013, 07:09 AM
cj5huntingrig
1974 CJ5
You realize your setup is forcing you to run both batteries all the time right? You should have a good alternator or you will never be able to properly charge both thereby defeating the purpose of having a dual battery setup.
X2 for the battery switch. Make sure you check out your charging voltage at both of the batteries. Even at idle, you should be getting above 13volts at both batteries. If you don't, you will need a stronger HD alternator.
E
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline
post #23 of 23 Old 03-01-2013, 04:03 PM Thread Starter
Galt
Galt's Avatar
1983 CJ7
E
Yes that was the point of the way I installed the batteries. My alternator is 105 amps. Which is more than enough. Batteries charge slowly over time. Anything fast like these 200AMP hd Alternators will cook your batteries. Ask me how i know....
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
Galt is offline
