need late cj5 leaf springs - JeepForum.com
post #1 of 6 Old 02-04-2012, 02:19 PM Thread Starter
Tfain
1978 CJ5
does anyone have a set. maybe someone who lifted there 5 and isnt using the stock springs. all i need is the stock ones. mine are flat in the back and almost flat in the front. i thought id look here first before i looked into getting them rearched
Tfain is offline
post #2 of 6 Old 02-04-2012, 02:45 PM
80cj
80cj's Avatar
1980 CJ5
I tried rearcing mine. They didn't retain the height very long. Ended up going to 2" lift kit. I think the problem was that in rearcing the springs, all they did was cold bend them. It's called resetting. Perhaps if you found a spring shop that did actual re-heat treatment, it may hold. But then you might be into the equivalent cost of anew set of springs.
80cj is offline
post #3 of 6 Old 02-04-2012, 02:52 PM Thread Starter
Tfain
1978 CJ5
thanks. thats why i wanted to ask here first. i have an SOA lift so i dont want to put anymore lift on it but i want it to sit higher than it does now but im low on founds. after getting my driveshaft im broke
Tfain is offline
post #4 of 6 Old 02-04-2012, 03:02 PM
80cj
80cj's Avatar
1980 CJ5
Maybe you can find some leaves off another spring pack and add them in. I've cut spring leaves to length with a metal cut off saw. Too bad you're not my neighbor. I have a bunch of spring packs under my house.
80cj is offline
post #5 of 6 Old 02-04-2012, 03:42 PM
Pathkiller
1974 CJ5
Well the bad news is that if you add more lift your new driveshaft will probably be too short.
Pathkiller is offline
post #6 of 6 Old 02-04-2012, 04:19 PM Thread Starter
Tfain
1978 CJ5
i got it cut a little bit longer just for that reson. its not going to make that big of a difference. im just going from worn out springs to new stock springs
Tfain is offline
removing the bottom leaf from leaf springs agear Jeep CJ Forum 22 09-03-2011 04:47 PM
assembling leaf springs; are leaf springs identical for left and right side? pazur Jeep CJ Forum 8 07-15-2010 01:08 PM
Leaf Springs Help rrtex1 Jeep CJ Forum 21 12-10-2009 02:16 PM
Leaf Springs bigjoe Jeep CJ Forum 2 06-27-2007 02:22 PM
Leaf Springs jeepwillies Jeep CJ Forum 2 04-01-2005 04:01 PM
