Need Jerry can gaskets. - JeepForum.com
post #1 of 20 Old 08-23-2008, 09:35 PM Thread Starter
OldSailor
1977 CJ7
I have a couple of regular 5-gallon steel Jerry cans - gas cans. I need the rubber-looking gasket that goes under the cap.
Anyone here know where I can buy them?
Thanks,
--Bob
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline
post #2 of 20 Old 08-23-2008, 09:45 PM
DirtEater
1982 CJ7
Good question. Did you check the usual places like Blitz, assuming they're Blitz cans anyway.
http://www.blitzusa.com/products/fue...ent/pfc5mc.htm
Terry ~ USN Ret. 30Sep07 : )
1982 CJ7 4.2L ~ T-999 ~ Dana 300 ~ SOA Conversion
Dana 30/AMC 20 with Truetrac - one piece axle - 4.10's
33" Toyo M/T's on Pro Comp Xtreme Series 1069
Borla header and Catback Exhaust System
Jeeperman bumper w/ Ramsey Patriot 8000 - Jeeperman tire carrier/bumper
DirtEater is offline
post #3 of 20 Old 08-24-2008, 12:31 AM Thread Starter
OldSailor
1977 CJ7
Thanks for the reply. I'll give Blitz a try.
post #4 of 20 Old 08-24-2008, 06:16 AM
petey156
might go to napa and get a big o-ring, i know they have a lot of large ones
petey156 is offline
post #5 of 20 Old 08-24-2008, 06:50 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If you can't find one, you might want to check Mcmaster Carr. You can pick up a sheet of thin "fuel resistant" rubber and cut a gasket out of it.
BESRK is offline
post #6 of 20 Old 08-24-2008, 02:56 PM
slacker92104
slacker92104's Avatar
Whatever you get make sure it is wide enough to cover the vent hole. I've noticed a bunch of ppl selling gasket for cans, but they are really for the spout which has a thinner gasket so it doesn't cover the vent. BESRK probaly has the best idea. I haven't been able to find any good replacements.
I did a search and found some here:
http://offroadrecovery.zoovy.com/cat...rrycansandacc/
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #7 of 20 Old 08-24-2008, 08:35 PM
JeepHammer
Running On Empty...
1973 CJ5
I can vouch for this...
Blitz and several others use a different size neck hole than the old Military 'Gerry' cans.
Military type cans vent through a little hole just under the lip of the cap.
Gaskets for the military type cans need a gasket wide enough and thick enough to cover this hole, or your can will 'Drool' when shaken up.
('Legal Gas Cans' have a vent in the back side of the can)
Blitz gaskets don't cover that hole sufficiently to keep it from leaking...
Ask me how I know that...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #8 of 20 Old 08-24-2008, 10:11 PM Thread Starter
OldSailor
1977 CJ7
My cans are "Blitz" brand cans. They have a small vent hole (I'm guessing about 1/16" diameter)under the cap gasket, at the uppermost portion of the hole.
The gaskets that came with the cans to go under the cap are wide enough that they cover this vent hole, which is sealed when the cap is sealed. However, the gaskets on the spouts are a little narrower, leaving the vent hole uncovered. Because of that, I can't use the spout gaskets under the cap, 'cause the vent hole will "weep" gasoline on the trails. Not a safe condition.
For the same reason, the suggestion of O-rings won't work -- they won't cover the vent hole.
I'll see what Blitz has to say tomorrow when I call them. If they don't sell them, I may be able to check out the local auto parts stores and see if I can get a couple of sheets of rubberized gasket material, such as is used for some diff cover gaskets.
Also, I seem to remember, from my younger days (a looong time ago), that some Jerry cans had cork gaskets under the caps. I'm pretty sure I can get some sheet cork gasket material about 1/16" thick -- that might work if I can't find any store-boughts. I can use the broken gasket as a template.
post #9 of 20 Old 08-25-2008, 07:19 AM
JeepHammer
Running On Empty...
1973 CJ5
Cork is a bad idea since it degrades when exposed to gasoline...
the 'Cork' we had as gaskets had a metal foil liner on them...
Anyway, I use roll gasket material to make gaskets that actually fit my military cans...
Some kind of synthetic stuff, like rubber with a cloth weave built into it.
Seems to be working find now...
If you do Surplus (Junk) stores, you might just run onto a stash of those rubber gaskets once in a while.
I ran into a pile of them in the '80's and just recently ran out! Now I'm making gaskets instead of just getting one out of 'Da Box'...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #10 of 20 Old 08-25-2008, 02:55 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Viton Rubber sheet... 1/16" thick..
http://www.mcmaster.com/param/asp/PS...reenWidth=1024
BESRK is offline
post #11 of 20 Old 08-25-2008, 05:21 PM
JeepHammer
Running On Empty...
1973 CJ5
Sounds about right.
Got it at the local NAPA store that caters to farmers and big trucks. Didn't work really good, but if you crank the lids down, it will seal...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #12 of 20 Old 08-25-2008, 07:45 PM
taylor4857
army surpluse store whould have tons of them ..
taylor4857 is offline
post #13 of 20 Old 08-25-2008, 08:00 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
.. you can also get the rubber thicker.. 3/16"? That might seal better against imperfections...
or yeah.. surplus store.
BESRK is offline
post #14 of 20 Old 08-25-2008, 08:21 PM
JeepHammer
Running On Empty...
1973 CJ5
Not since the military hasn't used Metal Gerry cans in about 15 years, they are all plastic since the mid 80's...
Like I said, I got a gob of them in the surplus stores several years ago, but you don't find them much anymore....
TOO FAR out of date.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #15 of 20 Old 08-26-2008, 09:17 PM
slacker92104
If it's a blitz can, the one down the page should work.
360 header gaskets jp360cj Jeep CJ Forum 9 10-09-2008 10:18 AM
Gaskets Gixxed Jeep CJ Forum 2 01-07-2007 07:03 PM
Gaskets mcktiger Jeep CJ Forum 3 10-25-2006 08:02 AM
Manifold gaskets. ScottJ Jeep CJ Forum 4 04-28-2006 08:36 PM
Dana 20 Gaskets dreski1 Jeep CJ Forum 2 01-25-2006 07:46 AM
