need info please - JeepForum.com
post #1 of 6 Old 04-02-2013, 09:00 AM Thread Starter
mexician282
need info please
In search of info on the engine in my 86 cj7. It is a 282 mexican engine. It has mexico stamped on side of block. Just cant find parts or info on it, PLEASE anyone help.
mexician282 is offline
post #2 of 6 Old 04-02-2013, 09:49 AM
Hurricane4
Factory (OEM) CID for AMC Jeep 6 cyl is 232 or 258 AFAIK.
The unbelievable we can do immediately . . . the impossible just takes a little longer.
Hurricane4 is offline
post #3 of 6 Old 04-02-2013, 11:28 AM
Davis77Cj
1977 CJ7
if it is an 86 then it should be a 258, also this could be a long block from Advance Auto IIRC they are manufactured in Mexico.
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
post #4 of 6 Old 04-02-2013, 11:29 AM
WindKnot
1977 CJ7
First, they really do exist. But not in a Jeep. Someone swapped it in.
The engine was used in AMC Hornets, Javelins, Concords, Pacers and Spirits. Knowing how the parts counters work with computers, try telling the guy the car is a 1982 Hornet or a Concord.
When you own a Jeep you learn that Jeep really stands for Just Employ Everybody's Parts. AMC outsourced everything. It's not uncommon to have a Ford ignition system and a GM Delco alternator, etc. Jeep owners have to lie to countermen all the time.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #5 of 6 Old 04-02-2013, 12:10 PM
Hurricane4
http://www.amcyclopedia.org/node/6985
http://en.wikipedia.org/wiki/AMC_Straight_6_engine#282
The 282 cu in (4.6 L) engine was produced by AMC's Mexican subsidiary Vehiculos Automotores Mexicanos (VAM) beginning in 1971 through 1986. This was similar to a 258 in stroke, cast with a larger 3.917 in (99.5 mm) bore, 0.16" larger than the 258, giving 281.7 cu in (4,616 cc).
Kudos to WindKnot & Davis77Cj - Good call!
post #6 of 6 Old 08-10-2013, 12:58 PM
rokjunki
the lady at auto zone pulled it up on the computer for my 85 jeep
this is a Mexican motor
rokjunki is offline
