need help will not idle?? - JeepForum.com
post #1 of 3 Old 08-27-2002, 07:33 PM Thread Starter
DIXIE
DIXIE's Avatar
I recently had a new carb put on my 85 CJ-7. It has idled fine for the last couple of months, however the last few days it will not stay running when I stop and the engine returns to idle speed. Any suggestions???
DIXIE is offline
post #2 of 3 Old 08-27-2002, 08:24 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Re: need help will not idle??
Sounds like a vacuum leak has developed - check the bolts that hold the carb on - also check ALL 48' of vacuum lines!
It is not uncommon for the carb bolts to work loose after the initial torqueing.
Steve
OldJeepguy is offline
post #3 of 3 Old 08-28-2002, 09:27 PM
Bryan L.
rough idle
What kind of carb is it? Try this list of things.fuel might be bad, vaccum leak, line collasping, filter pluged up, fuel pump maybe going out.
Bryan L. is offline
My CJ will not idle! taylorce1 Jeep CJ Forum 9 05-22-2009 03:10 PM
258 will run but won't idle Reddy012 Jeep CJ Forum 15 01-01-2009 07:06 PM
Idle Mix and Idle Speed on Weber jennandal Jeep CJ Forum 2 01-28-2008 07:41 PM
Idle RPM redcj576 Jeep CJ Forum 3 01-06-2008 10:03 AM
Bad Idle madadsnt Jeep CJ Forum 5 05-10-2007 07:11 PM
