need help! tranny advice - JeepForum.com
post #1 of 8 Old 01-26-2012, 01:44 PM Thread Starter
a1980jeepcj7
1980 CJ7
i have a 1980 jeep cj7 with 304 v8 motor. it has 4 speed tranny with reverse towards the passenger side and down. i think it is the t176 tranny. the tranny was grinding so i put a new clutch set in and it still continues to grind. sounds like the tranny might be toast. i was having trouble shifting into second and first gear. i wanted to know if i should get the tranny rebuilt, find one at a junk yard, or if there are any better transmissions that will bolt up to the bell housing seeing as it already has a brand new clutch, bearings,ect?
Thanks
a1980jeepcj7 is offline
post #2 of 8 Old 01-26-2012, 02:14 PM
davbytrace
1979 CJ7
I have a great condition T150 3 spd for sale for $200, and includes the bell housing.
davbytrace is offline
post #3 of 8 Old 01-26-2012, 02:20 PM
79jeepincj7
1979 CJ7
The 176 is a great 4spd especially to be behind a V8. Id either have that rebuilt, find another one or find a T18. The T18 was also a jeep 4spd but it had the grany low first gear which is much better for wheeling. You can find both of them on craigslist or possibly junkyards for not to much. Rebuilding will be on teh pricier side tho.
Wheel - Wreck - Wrench - Repeat!
The VIN says its a 79 CJ
79jeepincj7 is offline
post #4 of 8 Old 01-26-2012, 02:21 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Not to be insulting, but have you drained and flushed the trans, then ensure it has the proper amount of the proper gear oil?
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #5 of 8 Old 01-26-2012, 02:29 PM
mojo_matic
1980 CJ5
Originally Posted by 79jeepincj7 View Post
The 176 is a great 4spd especially to be behind a V8. .
Not really... behind a lethargic 304, it is a decent transmission. I wouldn't call it "great." If you plan to drop in a hotter engine later down the line, this would be a good time to consider an upgrade.
mojo_matic is offline
post #6 of 8 Old 01-26-2012, 02:42 PM
jeepsr4ever
jeepsr4ever's Avatar
Location: near wisconsin north of the twin cities minnesota
Your synchros need lube to spool up to speed. If your low on fluid you will get this issue and if it persists it will be irreversible.
[SIGPIC][/SIGPIC]
I design and build parts for AMC V8 racing engines, street or trail. If you have a specific performance question please PM me I will be glad to give you 100% accurate information.
Big ones line up...little ones get in a group
jeepsr4ever is offline
post #7 of 8 Old 01-26-2012, 06:50 PM
79jeepincj7
1979 CJ7
Good Point.. I guess I should have said your 304 v8.... and for a jeep trany that will take no extra work to bolt up... There are many other stronger tranies but for a factory jeep trany besides the T18 thats kinda the next of kin for a 4spd
post #8 of 8 Old 01-27-2012, 09:13 AM
80cj
80cj's Avatar
1980 CJ5
Lots of guys have the T-176 behind 360's. In fact the T-176 was used behind 360's from the factory in J series Jeep trucks.
80cj is online now
cj , grinding , jeep , t176 , transmission
Need Advice on Tranny MDonovan8 Jeep CJ Forum 15 11-19-2009 05:13 AM
Need advice on tranny swap msheffield Jeep CJ Forum 1 11-18-2007 12:02 PM
tranny drop advice BLS33 Jeep CJ Forum 8 06-08-2006 06:53 PM
Need tranny advice BAD!! imtheant Jeep CJ Forum 30 04-23-2006 08:27 PM
Need advice - '76 CJ5 Engine/tranny swap dixiediesel Jeep CJ Forum 6 06-28-2002 12:57 PM
