Need help on tires, rims - JeepForum.com
post #1 of 12 Old 03-20-2013, 03:59 AM Thread Starter
450SLMercedes
1983 CJ5
I have a stock CJ5 with only a small shackle lifted front to offset the winch weight.
I found some new rims in a pawnshop for cheap that fit (5 X 5 1/5) and are what I wanted as for the look.
Here's the deal. Rims are 17X9 with a back space of 5 1/4", which is pretty close to center. I haven't bought tire yet and want advice on what to buy if any for these rims. Will they work? Which tires (size ) would work with my rig. Driving will mostly be asphalt. Thanks
450SLMercedes is offline
post #2 of 12 Old 03-21-2013, 01:15 PM
Lpat
I am not sure what height would be best for you but width wise I would go with 12.50. 10.50 will work if all you do is drive on roads but 12.50 are a perfect fit on 9" wheels
Yeah I've got chrome....but then again I've always made it home!
Lpat is offline
post #3 of 12 Old 03-21-2013, 01:41 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
I agree w/Lpat. Tire rack can give you a better answer if you input your vehicle info, and click on the +1 (size) option. They also tell you when you've gone to big at checkout. Like that can happen! IMHO I like BFG All Terrains for your applicatyion. But then again I usually drive on pavement instead of asphalt.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #4 of 12 Old 03-21-2013, 01:58 PM
JeePete
1983 CJ7
What did those rims come off of? Pawn shop prolly wont be much help....but I'd
try fitting them on the CJ first....
17" sounds like much newer (Jeep) vehicle, which the hubs are different.
JeePete is offline
post #5 of 12 Old 03-21-2013, 03:12 PM
Mr_Ranger
1978 CJ5
So nobody is concerned about the 5 1/4" backspacing? Sounds like a lot to me.
Mr_Ranger is offline
post #6 of 12 Old 03-21-2013, 03:43 PM
lucdog
lucdog's Avatar
1980 CJ5
I'm having a hard time believing they fit. Mainly the center hole. Have you actually bolted them to the Jeep? I also think with a narrow trac axle you are going to have problems with tires rubbing the springs when turning, with any tire over a 9.50.
I guess it is possible someone special ordered these rims.
Did you actually measure the bolt hole pattern? Correctly?
This should be interesting to see work out.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #7 of 12 Old 03-21-2013, 04:33 PM
Lpat
the backspacing may not be enough to clear the springs, but if you're getting them at a pawn shop I am assuming it is a good deal and since they are what you want you can get some wheel spacers for them. so even if the bolt pattern isn't right you can change that with spacers. tire size depends on what you are running right now, how much room you want there to bee from the top of re tire to the wheel well and if you're planning on going up a few inches rehearing can also be a factor
Lpat is offline
post #8 of 12 Old 03-21-2013, 08:05 PM
19jeep85
5 x 51/4 is also the bolt pattern for 1/2 ton dodge from '94 on and they fit on CJ's, I've swapped mine a few times to see what 20's looked like on my CJ. I'd be concerned about the back spacing though and rubbing. Also make sure the center hole is large enough to fit the hubs on the front. A good P metric tire in 17" is a 265/70R 17 which are about 31" tall and 9.5" wide.
Sent from AutoGuide.com App
The heart of the wise inclines to the right, but the heart of the fool to the left .
19jeep85 is offline
post #9 of 12 Old 03-22-2013, 08:18 AM
hutch1200
hutch1200's Avatar
1979 CJ7
"I've swapped mine a few times to see what 20's looked like on my CJ."---19jeep85
Halloween? Lose a bet? Just kidding. Any pics?
post #10 of 12 Old 03-22-2013, 11:47 AM
Mlaughlin8
1980 CJ5
Be carefull!!! I bought 18x9 rockstars for my narrow track cj5 and I had to put wheels spacers just to keep the tire from smashing the frame in the rear... I put 1 1/2" spacers all the way around and now I clear all corners. Here is a pick with spacers and 33x12.5 mud grapplers!
Mlaughlin8 is offline
post #11 of 12 Old 03-22-2013, 01:10 PM
19jeep85
Now I didn't say they stayed on! But seriously I have a set of 35's mounted in 20's for my summer tires on my Ram and wanted to see what 35's on my CJ would look like after my lift was installed. So before buying a set, and since they weren't on my truck yet, I slapped them on the Jeep, drove around the hood quick...cranked the bass, wore my hat backward and drank a 40...then immediately took them off! Sorry no pictures but I may put them on again just for the street cred and photos!
19jeep85 is offline
post #12 of 12 Old 03-22-2013, 02:52 PM
hutch1200
hutch1200's Avatar
1979 CJ7
In this case we need mugshot pics!
I wonder if my 20s from my '11 Big Horn Ram will work. I could pull that off, and make that **** look good!
