need help with t176 - JeepForum.com
post #1 of 7 Old 02-05-2010, 12:00 AM Thread Starter
jefflacy
need help with t176
like the title says need some help with a t176
problems
It grinds a little when not in gear and not in on clutch but not bad at all almost sounds more like a throw out baring. Also grinds all the time and really bad in 1, 2, 3 but not in forth. So been searching and sounds like the counter shaft. Trying the cheapest first i changed gear oil just to see if it would help some. But now since i did that it pops out of 4th.
Were im at now
Pulled the top plate just to look in there and see is anything was damaged bad like gears or any of the synchronizer stuff for 4th nope all good but did find that the front baring is missing half the balls in it. Which is letting the shaft move around which i am asooming is my problem. All the gears look good so i think a master rebuild and a shifter repair kit should get me back going
dose this sound like im going in the right direction
jefflacy is offline
post #2 of 7 Old 02-05-2010, 12:41 AM
80cj
80cj's Avatar
1980 CJ5
Yep. A bearing with half it's balls missing?
80cj is offline
post #3 of 7 Old 02-05-2010, 02:24 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Hopefully he probably just lost the spacers between the balls and the balls are all collecting together.
John Strenk is offline
post #4 of 7 Old 02-05-2010, 06:34 AM
BioTex
1979 CJ7
Same thing with mine. I replaced the front bearing with one from NAPA, and bought a small parts kit. Rebuilt it using the manual floating around on this site, and it is good to go. Tough little trannys.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #5 of 7 Old 02-05-2010, 07:12 AM
John Strenk
1976 CJ5
This one?
Floating T-17X Manual
post #6 of 7 Old 02-05-2010, 08:17 PM Thread Starter
jefflacy
got the trans pulled out today and all the balls were together and just lost the spacers between the balls and the balls are all collecting together. No gears were messed up besides the reverse sliding gear which ant that bad and was missing a sycro spring on 4th. Which is why i think it was poping out of 4th. So ordered a master rebuild kit with sycro blocking rings and a 2 springs and a 3 4 slider. So i think i should be all set when it all comes in.
jefflacy is offline
post #7 of 7 Old 02-06-2010, 03:33 AM
John Strenk
1976 CJ5
Good, you're half way done.
Get a good, and i mean a good transmission snap ring pliers, and go to town.
Order one now when you are waiting for parts.
Transmission Bearing Retaining Ring Pliers - International Scout Parts - Scout II Parts - Your Authorized IH Lightline Dealer
Should I buy this T176? NelsonATC Jeep CJ Forum 12 12-03-2009 10:49 AM
3 spd or a T176 behind a 360 Johnyakimo1855 Jeep CJ Forum 1 04-17-2009 03:04 AM
T176 & 300 in Cj5 starky Jeep CJ Forum 4 05-30-2007 07:11 AM
What came with the T176? JOKER4INK Jeep CJ Forum 2 05-01-2006 10:36 PM
t176 vs. T5 for a CJ Hibbitz Jeep CJ Forum 27 10-08-2005 12:52 PM
