Need Help With T-18 - JeepForum.com
post #1 of 13 Old 02-06-2010, 07:30 AM Thread Starter
staplesmotorspo
Need Help With T-18
I have a t-18 I bought on ebay. It is a nice peice but I can not figure out what it is for the life of me. There are so many variations. The top cover has 13-01-097-907 and the side by pto port has 13-01-065-906 it apears to have about 7 an 3/8 of stick out on input shaft. The spot where pilot would ride is roughly 11/16 it has the jeep bolt pattern where you have to use the stud on a t150 bell housing. I am trying to find a clutch and pilot bearing that will work with this. Any help would be greatly apreciated. Part numbers would also be a big help. This is my first jeep build and I did it ground up this site has been awsome for help.
staplesmotorspo is offline
post #2 of 13 Old 02-06-2010, 07:41 AM
CSP
Based on the input shaft length it sounds like a '72-75 CJ version with the 4.03 first gear.
Do you have the correct bellhousing? That input shaft is too long to use with the T150 bellhousing.
You'll also need the diameter of the input shaft for the right clutch. It's probably 1-1/8".
CSP is offline
post #3 of 13 Old 02-06-2010, 07:42 AM
rockslide
1981 CJ5
rockslide is offline
post #4 of 13 Old 02-07-2010, 07:06 AM Thread Starter
staplesmotorspo
I had planned to use the t-150 bell housing I have. Do they make a spacer so I can use that. The in-put shaft is close to 1 1/16 just slightly less than that. The novak site is great but the specs from this trans I do not see on there. These t-18's are great but they sure are hard to identify. Thanks for the help please keep it coming.
post #5 of 13 Old 02-07-2010, 07:10 AM Thread Starter
staplesmotorspo
Actually the novak site says the 7.43 stick out was from 76' thru 79' with out the use of a spacer. So anyone know what bell housing belongs with it.
post #6 of 13 Old 02-07-2010, 07:20 AM
tractor1
1979 CJ5
tractor1 is offline
post #7 of 13 Old 02-07-2010, 08:21 AM Thread Starter
staplesmotorspo
I must be measuring input size wrong. I am measuring the splined part and that is 1 1/16 but my t-14 measures the same and that is suppose to be 1 1/8 so should I be measuring under the bearing retainer.
post #8 of 13 Old 02-07-2010, 09:27 AM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Could you take a picture?
Splined sectioned should be same diameter as the section under the retainer.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #9 of 13 Old 02-07-2010, 12:04 PM Thread Starter
staplesmotorspo
I cant get a pic to load but mine is exactly like the black one on the ground on the right in this link.
Jeep Transmissions: T-98, T-18, T-18A
post #10 of 13 Old 02-07-2010, 03:12 PM
No_Bs
1977 CJ5
If it is exactly like the one in that pic (bulge on drivers side rear) it is a '79 CJ T18. 1 1/16" input, T150 bell will work.
1977 Cj5, 258, T-18, 2.46:1 Dana 20, 2.5" BDS lift, OBA, 38.5's. Chevy 60 frt, 14b Rear, Full hydro, 102"wb, full DOM cage.
No_Bs is offline
post #11 of 13 Old 02-07-2010, 03:27 PM Thread Starter
staplesmotorspo
Its like the black one in pic has the flat side not the bulge on bottom for reverse. Its definatly 1 1/16 but the disc has a little more slop than i would like and the input shaft is not worn, Im at a loss here. Really getting frustrated. I do belive the t150 bell will work but I need to get disc problem figured out. Any ideas? I told myself I was going to get this figured out today it was my only goal for the day.
post #12 of 13 Old 02-08-2010, 08:48 AM
CSP
If you're using the T14 clutch disc I would expect some slop. They really are 1-1/8", which would be sloppy on a 1-1/16" input shaft.
If you've identified it as a '79 CJ T18, get a clutch disc for a '79 CJ with a T18.
I'm not sure why I thought it was the pre-76 T18. I measured one I have this weekend and the input shaft was 9-5/8" long.
CSP is offline
post #13 of 13 Old 02-08-2010, 01:21 PM Thread Starter
staplesmotorspo
Thanks for the help I will get a disc and try that.
