Need help replacing door handles 85 CJ-7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Need help replacing door handles 85 CJ-7
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 09-21-2014, 09:38 PM   #1
Shas-85
How to replace 85 CJ-7 outside door handles.
Hi all,
I am attempting to replace the outside door handles on my 85 CJ7 hard doors. I cannot see how to get to the handle. Most of what I am reading it looks like the latch cover(black in photos) should be removable, however on my doors this cover is riveted on.
Anyone out there with experience replacing their door handles can you take a look at my pics and tell me if this cover should be riveted? If it is supposed to be removable I will drill out the rivets.
Thanks!
Shay
Shas-85 is offline   Reply With Quote Quick reply to this message
Unread 09-21-2014, 10:25 PM   #2
CrankyD
1983 CJ7
Here you go! This thread is pretty much definitive.
http://www.jeepforum.com/forum/f8/ga...ml#post8290416
CrankyD is offline   Reply With Quote Quick reply to this message
Unread 09-21-2014, 10:58 PM   #3
only in a jeep cj
Drill out rivets, there are two more torx screws behind the seal, remove cover, swing away the rod latches, remove the inside handle/lock and two rods together out of that hole, remove the striker assembly and you'll see the backside of the outer handle, remove rod.
To remove handle, gently lift the lock tab at the bottom of each wedge (on the sides) with a small screwdriver, gently tap the wedge upward and the handle will come free. IN some cases, the glass may get in the way and might have to be removed. Dont pry against it or hit it for obvious reasons.
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote Quick reply to this message
Unread 09-22-2014, 03:15 AM   #4
Shas-85
Thanks a ton...this helps!!!
Shay
