need help re-mounting body of CJ - JeepForum.com
post #1 of 1 Old 11-11-2002, 10:06 AM Thread Starter
markpat3
Question need help re-mounting body of CJ
Thanks for all the tips for painting the cj.
I now need to mount the body back onto the frame. The problem is when we were taking the body off the frame, we had to cut most of the bolts due to the nut slipping. Has anyone encountered this? If so, what do I need to do to get the a new nut in place?
Do I need to weld a bolt to the body, then a nut under the frame?
I'm just not sure on the best way to go about accomplishing this.
If you have any pointers, I would appreciate it.
Once again, thanks for the input on painting it.
markpat3 is offline
1976 CJ7 body mounting bushings ucsbtexan Jeep CJ Forum 2 12-31-2009 06:35 PM
Mounting E-brake pedal assembly to fiberglass body chet44 Jeep CJ Forum 4 10-12-2009 12:27 PM
Fiberglass body mounting questions Arcticcat843 Jeep CJ Forum 6 06-04-2009 07:49 PM
5 point harness mounting options in fiberglas body supraman1990 Jeep CJ Forum 12 04-05-2007 07:35 AM
mounting fiberglass body oreo_n2 Jeep CJ Forum 2 10-02-2003 05:55 AM
