Need help with radiator/pulley clearance - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Need help with radiator/pulley clearance
The ULTIMATE "Selectable" Locker System! BroughOconee Off-Road Free Shipping Lifts Tires Bumpers Tops andNitro Gear Packages Now Available at Rockridge 4wd
Unread Today, 08:18 AM   #1
Myren
1979 CJ7
So I have a '79 CJ7 w/ 258. The block is a re-built '82 0r '83. When I bought the Jeep it had an electric puller fan in front of the radiator wired backwards. The fan was attached through the radiator and was pulling/deforming the fins. Last weekend I went to install a Contour dual fan and there is not enough clearance. The fan is 3.25" deep or so but I'm only getting 2.25" from the pulley to the radiator. So my questions are 1) Is this the correct pulley/water pump?
[IMG][/IMG]
[IMG][/IMG]
2) Is the engine mounted too far forward?
It seems like every project I attempt has parts that work but are not stock replacements. Even the flex-a-lite direct replacement fan has a depth of 3" and this is making me question what is going on. Any help would be appreciated.
Myren is online now   Reply With Quote
Unread Today, 09:15 AM   #2
dirtdudeaz
1983 CJ7
I am interested in this as well...as I am going through the same exact deal...
I have a 3 row aluminum replacement radiator and the contour dual fans. My first go was the fan was touching by a half inch. I was able to adjust my mounts on the fan to readiator and suck it in a little. I think it's going to be damn close when I try it again tonight. The next plan is to shave a little of the molded fan plastic where it rubs the water pump pulley.
dirtdudeaz is online now   Reply With Quote
Unread Today, 09:58 AM   #3
WindKnot
WindKnot's Avatar
1977 CJ7
There isn't much room, that's for sure. I have a three row radiator and just the stock fan and pump.
Here's what I have on my '77...
It cools just fine here in Arizona BTW. Why do you feel you need an electric fan?
Paved roads are just for getting you to the starting point!
WindKnot is offline   Reply With Quote
Unread Today, 10:32 AM   #4
Group_er
Interesting.... Mine looks about the same as that. Im running A YJ frame, I just summed my lack of clearance up to me welding my motor mount to far forwards. Im running a rad for a v8 cj, with my straight 6... I can get pics if need be
I was running a flex a light flex fan with a smaller spacer, but recently installed the only electric fan I could squeeze in there:http://www.jeepforum.com/forum/f8/4-...dings-2670466/
Group_er is offline   Reply With Quote
Unread Today, 10:56 AM   #5
WindKnot
WindKnot's Avatar
1977 CJ7
Just my opinion, but...
CJs are very simple machines. They were sold all over the planet and ran just fine with a mechanical fix bladed fan. It wasn't until air conditioning became an option that Jeep even considered a fan shroud. I believe if you're running a simple 258 and you have to go to an electric fan to get proper cooling, you may be treating the symptoms instead of finding the cause. Not even the V8s were equipped with electric cooling.
As long as your radiator and block are clear of scale and other deposits, your water pump is running fine and you have the right thermostat you should be good as gold. If you're running too hot, there's a cause for that.
Unread Today, 10:59 AM   #6
Group_er
I agree. I went electric fan because my flex fan was very loud in my opinions. Never had a shroud with it.
Unread Today, 11:16 AM   #7
dirtdudeaz
1983 CJ7
I would agree, but I would also assume that Jeep went mechanical because it's cheap and simple and gets the job done.... I am switching so that I don't have a fan running all the time and and can be a little more efficient in cooling, and have a few extra HP from not having the load from the fan.
Unread Today, 12:30 PM   #8
WindKnot
WindKnot's Avatar
1977 CJ7
Which was the whole point of a Jeep. 258s are happiest running a warm 210° or so.
Let us know how you get it to fit. Too many times these threads are left open ended.
