Need help, Question with amc 20 open to lsd - JeepForum.com
post #1 of 5 Old 05-19-2013, 07:09 PM Thread Starter
turbonusse2
I have a off road trip coming up next weekend and finally opened up the spare amc 20 axle that i have have for years and it has lsd!! i should have looked at it when i bought all the parts. i counted the teeth on the gears and they come out to be 3.07 gears. would i be able to put this carrier into the axle under my jeep with 3.73 gear? thanks
live and learn
turbonusse2 is offline
post #2 of 5 Old 05-19-2013, 09:38 PM
texasdave
texasdave's Avatar
1980 CJ7
Wouldn't think so.
texasdave is offline
post #3 of 5 Old 05-19-2013, 09:50 PM
rplivin
Yes 2.73 carrier is the only one that is different. 3.73 gears on 3.07 carrier will work as long as you shim it and get the proper setup on the gears. Also check the clutches in the LSD.
rplivin is offline
post #4 of 5 Old 05-19-2013, 09:51 PM
rplivin
Also if you have the Dana 30 up front carrier is 3.54 and numerically down and 3.73 numerically higher
rplivin is offline
post #5 of 5 Old 05-19-2013, 11:41 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Which LS is it? A trac Lok isn't worth the effort.
jeepdaddy2000 is offline
