Need Help Please!!!!! - JeepForum.com
post #1 of 4 Old 09-09-2002, 11:48 PM Thread Starter
mbaldwin11
i'm and eagle scout trying to repair and restore my cj-7 that i was given for becoming an eagle scout. i need a lead on where i can get a replacement upper window frame for the passenger side for a full hard door. mine has been eaten by that horrible thing known as rust and it is the last thing i need to do in order to paint it. any help that can be given is greatly apprieciated.
sincerely,
matt
mbaldwin11@aol.com
mbaldwin11 is offline
post #2 of 4 Old 09-10-2002, 06:52 AM
dana60cj
dana60cj's Avatar
I have never seen just a replacement frame. As in the u-shaped top of the door which holds the windows? A junk yard with a set of doors that you could cut it off, I guess?
Welcome aboard.
dana60cj is offline
post #3 of 4 Old 09-10-2002, 10:55 AM
jonesmatty
It will be really tough to find that part. You would be hard pressed trying to convince a junk yard to cut that off because they get 800 bucks for a pair of doors. Maybe you'll get lucky and the bottom of some door will be mangled but the top is okay, you'll really have to do your homework and probably be willing to drive a good long way once you find a yard like that.
I would recommend buying some used doors.
jonesmatty is offline
post #4 of 4 Old 09-10-2002, 03:41 PM
rebelcj7
The part in shich you are describing is un buyable, unless like one of em said to haver someone chop off that part.. but then whats the fawkin point? buy a new set of doors
Big n fugly 78 cj7.. built baby built
51 willy's in the process...
**MoROC Presidient**
rebelcj7 is offline
