Need help with painless harness on 360 - JeepForum.com
post #1 of 4 Old 07-19-2010, 09:43 PM Thread Starter
83seejay7
1983 CJ7
So I'm in the middle of hooking up my new Painless wiring harness to my 83 CJ-7. I recently swapped in a 360 from an 87 Grand Wagoneer and I'm a little confused on the engine wiring. Does anyone have any insights into hooking this up to a 360?
Am I correct that the CJ came with a Duraspark ignition (CJ originally had the 258)? The 360 has a Ford coil on top so I'm assuming the Grand Wagoneers were equipped with Ford ignition systems.
Any help you can give is greatly appreciated. This is all just one step above my talent level (never been too good with ignitions).
(Also, where the heck would the ballast resistor be? Pretty sure I didn't see one when I took out the old harness.)
1983 CJ-7
AMC 360 w/ T999 Auto
33" TrXus MT's under 5" of lift
4.10s w/ a Detroit SofLocker in the back
Herculined Tub
83seejay7 is offline
post #2 of 4 Old 07-19-2010, 10:44 PM
jp360cj
1977 CJ7
Is it a canister coil? My '78 360 has a slip on connector for the coil and it says Ford. It's the same as the 304s and 258s. I believe the newer ones are also the same, but not 100% sure
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #3 of 4 Old 07-19-2010, 11:00 PM
82JeepCJ7
1982 CJ7
The 258 and 360 use the same Ford ignition. Should be no issues. The electronic ignition (duraspark) did not require the use of a ballast resistor. Ballast resistors are mainly used with points type ignitions.
82JeepCJ7 is offline
post #4 of 4 Old 07-20-2010, 05:29 AM Thread Starter
83seejay7
1983 CJ7
Yep, canister coil. Good to know that I don't need the ballast resistor. Just trying to make sure I have all the wires hooked up correctly.
1983 CJ-7
Herculined Tub
360 , ignition , painless , starter , wiring
Centech, Painless or other harness RetiredSERE Jeep CJ Forum 22 10-15-2009 07:07 PM
painless wiring harness? quader400 Jeep CJ Forum 18 03-28-2007 10:49 AM
Painless harness question Galt Jeep CJ Forum 7 07-12-2006 11:55 AM
Painless harness issue bods7 Jeep CJ Forum 1 06-03-2005 08:17 AM
Where did you buy your painless harness? BIGJMCCONNELL Jeep CJ Forum 7 09-08-2003 08:33 AM
