Need Help installing YJ 1/2 Doors on CJ7 - JeepForum.com
post #1 of 3 Old 10-07-2002, 08:59 PM Thread Starter
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I just got some factory 1/2 doors from an 94 YJ Wrangler that I want to put on my 84 CJ7. The doors didn't seem to fit right when I tried them the first time. Do I need to switch the hinges on the CJ7 (or the doors) to some other type? I believe the CJ7 was a factory soft-top. I do have the right kind of striker posts for the door latch, but the fit between the YJ door hinge and the hinge on the CJ tub is too tight for the door to swing either way. The hinges on the tub are part of a Kentrol brand stainless hardware package and work with my Bestop soft top and soft doors. The hinges on the YJ doors are the factory ones. Any ideas on how to proceed?
Thanks, Tim
CJ7-Tim is offline
post #2 of 3 Old 10-08-2002, 05:07 AM
JIM79CJ7
JIM79CJ7's Avatar
Loosen the hinges attach to the body and close and align the door . Tighten the nuts on the hinges . If that is not enough adjustment you will have to loosen the hinges on the doors an proceed the same way . HTH
Good Luck , JIM :{>
originally posted by Mikeythefireman :
Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there.
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff
2003 Inca Gold Rubicon , <------ Sissy jeep :)
JIM79CJ7 is offline
post #3 of 3 Old 10-09-2002, 06:21 PM Thread Starter
CJ7-Tim
CJ7-Tim's Avatar
Update
Thanks for the help. I had to put a shim behind one of the lower hinge mounts on the body, align the lower hinges on the body straight up and down, and then I had to loosen the hinge part on one door to move the door towards the rear so it would fit the opening and latch shut. Kind of a bummer because the factory didn't paint behind the hinges and now I have a hinge outline in grey primer on the drivers door. Oh well, the doors are great anyways.
CJ7-Tim is offline
Should I make full doors into half doors? NWA_CJ7 Jeep CJ Forum 20 04-25-2011 06:41 PM
safari doors vs half doors JeepnBlake Jeep CJ Forum 3 04-04-2008 08:10 PM
Cj-7 doors revisited-hard doors the answer? newjeepowner Jeep CJ Forum 2 11-12-2007 08:27 AM
Installing Glass into hard doors...Help ollietonk Jeep CJ Forum 2 09-18-2007 10:41 AM
Supertop half doors vs 1/2 doors CJ5 rcsutton Jeep CJ Forum 2 05-12-2004 11:10 PM
