Need help with ignition - JeepForum.com
post #1 of 7 Old 10-25-2010, 08:38 PM Thread Starter
Thepc
1973 CJ5
So I just got my CJ5 and the guy I bought it from let it sit for 3 years. I have replaced the solenoid, the solenoid to starter wire, and had the starter tested. The old solenoid would click when I turn the key, but the new one will not even do that. When I switch back the old solenoid will still click. I tried jumping the new solenoid and it will click, but not keep spinning. Any and all help is appreciated.
Thepc is offline
post #2 of 7 Old 10-25-2010, 09:13 PM
SecretSquirrel
1980 CJ7
Obvious question: Is the battery good?
A solenoid is just a switch. A multimeter set to ohms and one lead placed on each big post, while someone turns the key will tell you if it is working.
If it is I would make sure that I had a good ground going to the starter driectly from the battery, and verify that all the connections from my battery all the way to the starter were clean and tight
SecretSquirrel is offline
post #3 of 7 Old 10-25-2010, 09:46 PM
Trapshooter
Try a different battery or jump it with another vehicle. Make sure to go to ground somewhere OTHER than the battery in the Jeep, if you try a jump.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #4 of 7 Old 10-25-2010, 09:51 PM Thread Starter
Thepc
1973 CJ5
This gonna sound stupid but I did not know I had to ground the starter. This is my first jeep and really my first car project. I guess the ground cable got lost during the 3 years it was sitting in a barn I have a brand new battery in it so do I just ground it directly to the battery and where do I connect the ground wire? Thanks for the replies btw
Thepc is offline
post #5 of 7 Old 10-25-2010, 09:57 PM
popascj7
1976 CJ7
Connect the other end to a starter mounting bolt
popascj7 is offline
post #6 of 7 Old 10-26-2010, 02:43 AM
raperfam
1977 CJ7
do a search on jeephammers dedicated grounds this will not only ground your starter but alot of things we seem to forget ---and is very cheap up-grade---good luck
raperfam is offline
post #7 of 7 Old 10-26-2010, 01:57 PM Thread Starter
Thepc
1973 CJ5
OK so that was just a grounding issue, but unfortunately when I got it working I found out the engine is seized up. So I think I will drop a Chevy 350 I have laying around into it. Does anyone have any advice or links to parts I will need? My Jeep is a 73 with the AMC 304 and a T18 Transmission. Thanks for the help so far
Thepc is offline
help needed , ignition problem , solenoid , starter issue
MSD ignition? jeepsteads Jeep CJ Forum 17 02-22-2007 09:15 AM
Ignition CrashDrew Jeep CJ Forum 2 02-12-2007 04:07 PM
MSD Ignition gregsteele1979 Jeep CJ Forum 0 01-22-2007 07:02 PM
ignition help(i think) jeepin in maine Jeep CJ Forum 9 12-15-2006 03:39 PM
Ignition help mongooztt Jeep CJ Forum 9 12-25-2004 11:48 PM
