Need help identifying transmission and t-case - JeepForum.com
post #1 of 5 Old 01-01-2009, 09:44 PM Thread Starter
w1llster
I just bought a 1978 CJ-5. It has a 304 motor. The following is on the drivers side of the transmission "A-CP-OU". On the top there is "1 (followed by something that looks like a circle with the letter A inside the circle) then 3227078". I think it's a 3 speed but I'm not sure. The transfer case has a tag on the end of it with "300596-130 and underneath that is 5359089". I bought a Chiltons manual and I can't find any of these numbers in it. Any help is greatly appreciated.
w1llster is offline
post #2 of 5 Old 01-01-2009, 09:48 PM
clerihew82
1977 CJ5
Got any pics??
clerihew82 is offline
post #3 of 5 Old 01-01-2009, 09:55 PM
whittlecj
1980 CJ7
I'm not sure if the numbers are more than date codes or seriel numbers. Your trans code, including the 1A also shows up on some AMC 20s according to some other posters. You might try looking at the factory options on www.jeeptech.com . The trans could be a T150 and the transfer case could be a Dana 20. Good luck!
______________________________________
In Process: 2002 4.0L and NV3550 Swap
whittlecj is offline
post #4 of 5 Old 01-02-2009, 08:21 AM
Cherokeester
Cherokeester's Avatar
1980 CJ7
If everything is still stock you have a T-150 three speed tranny and a Dana 20 transfer case. The shift pattern on your tranny is.
R 2
1 3
1980 CJ-7 with a AMC 401, RE 4.5" Lift, 4-1 Dana 300, Holley TBI Projection, 35" Goodyear MTR's
2010 Rubicon Unlimited
1997 TJ with various enhancements
Cherokeester is offline
post #5 of 5 Old 01-02-2009, 08:56 AM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Yeah, prolly a T150. Just post a pic and someone will tell you for sure.
My '70 CJ5 Build Thread:
jayhawkclint is offline
Need help identifying this automatic transmission theplasterman Jeep CJ Forum 6 12-30-2009 10:33 AM
Several T case and transmission questions bluesman423 Jeep CJ Forum 7 06-25-2009 03:15 PM
Transmission and Transfer Case ID RetiredSERE Jeep CJ Forum 4 02-21-2009 05:08 PM
Need Help Identifying Trans, Transfer Case, Front/Rear Differentials Drsafety Jeep CJ Forum 7 07-05-2008 07:52 AM
Transmission/T case replacement on a CJ5 ickthoose Jeep CJ Forum 5 08-24-2007 07:34 AM
