-   -   Need help! How do i get this off! (http://www.jeepforum.com/forum/f8/need-help-how-do-i-get-off-1491121/)
backwoods_cj8 03-10-2013 03:21 PM
1 Attachment(s)
I've got a 84 cj8. The keys broke off in ignition. I rented steering wheel and lock plate kit from a local parts store. Steering wheels off but this dude does not want to move. Need some help. Thx guys.
scottymac62 03-10-2013 03:35 PM
With one of these. It will come off. Use a ratchet and start cranking!
http://www.4wheelparts.com/Fabricati...FYGqPAodtzEACQ
walkerhoundvm 03-10-2013 03:36 PM
Did you get the little lock ring off? I can't remember what order all of this goes in, but at some point there's a little lock ring that's holding everything on and you need a very small needle nosed pliers and a ton of patience to get it off.
backwoods_cj8 03-10-2013 05:56 PM
I'm guessing this steering wheel is a grant. Makes since. Thx Scottymac
Always2L8 03-10-2013 06:14 PM
2 Attachment(s)
This maybe too much information
If that is part of an aftermarket steering wheel, then do as scottymac62 suggested.
After that, the stock column has a stamped metal "lock plate" that has a spring behind it that forces the lock plate into the lock ring. In order to get the lock ring off, you need to compress the spring to get access to the lock ring. For a stock column it is best to get a "steering lock plate tool" to compress the spring. You can do it without the tool but it is a major PIA to get the lock ring off and on.
Below is a stock steering column. #2 is the lock ring that goes around the steering shaft. #3 is the stamped metal lock plate. #4 is the spring that pushes the lock plate into the lock ring. Unfortunately this doesn't show the steering shaft.
And below that is a picture of the "steering lock plate tool". You can see the lock ring (#2) around the steering shaft (bottom of the larger splined area).
Good Luck
backwoods_cj8 03-10-2013 06:38 PM
Thx always.. Good info much appreciated. Any other "special tools" that will make this go as smooth as possible.
DougE 03-11-2013 08:30 AM
A gear puller will get that steering wheel hub off. $20 at Harbor Freight. Pick up their steering lock plate removal tool while you're there also.
The time now is 09:17 PM.
