need help with grinding noise - JeepForum.com
post #1 of 7 Old 01-16-2010, 04:48 PM Thread Starter
jefflacy
have a 85 cj7 with a t156 and a dana 300 and in 1 2 3 there is a grinding comeing from the tranny or t case dont really hear it in 4th but when down shifting it is really loud
jefflacy is offline
post #2 of 7 Old 01-16-2010, 06:29 PM
semikrazy
1977 CJ7
Does it do it while your shifting or with the clutch in? How about in 4wd?
semikrazy is offline
post #3 of 7 Old 01-16-2010, 07:37 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Being 4th is direct drive, where input and output shafts are locked together, I would almost have to say it is in the bearings for the cluster shaft. I can't remember the technical name for the shaft...
Rick
Cutlass327 is offline
post #4 of 7 Old 01-16-2010, 10:07 PM Thread Starter
jefflacy
it dosent make it until you let out on the clutch when shifting
if your in on the clutch dose not make it at all
makes it 2wd 4hi and 4 low
jefflacy is offline
post #5 of 7 Old 01-17-2010, 03:01 AM
80cj
80cj's Avatar
1980 CJ5
Cutlass327 is right. The countershaft cluster gear is used in 1,2,3 and reverse but not in 4th because it's locked directly to the input shaft when in fourth. If it's noisy in all gears besides fourth, it would probably be the cluster gear bearings. Sounds like tranny teardown time.
80cj is offline
post #6 of 7 Old 02-02-2010, 10:19 PM Thread Starter
jefflacy
So its getting worst and now poping out of 4th so its time i start looking for a rebuild. But donno what im looking for from what i have read i thing the noise is the countershaft cluster gear but not sure what i need.
Is this everything i need to fix the problemMaster Overhaul kit for T176, T177, T178 transmissions BKT170
if not what on this page do i need Jeep CJ Series OEM Style Replacement Parts - T-176 and T-177 4 Speed Transmission Parts for 1981-84 CJ including Transmission Case, Rear Bearing, Rear Oil Seal, Cluster Gears, Countershaft, Reverse Idler Shaft, Reverse Sliding Gear, and more. - Quadr
jefflacy is offline
post #7 of 7 Old 02-02-2010, 10:28 PM
80cj
80cj's Avatar
1980 CJ5
Sounds like it's time to tear it down. I have the T-176 repair section of the FSM scanned to PDF file. PM me your email address and I'll gladly email it to you. tThe master overhaul kit should do it. When you tear it down you'll find out if you need anything else (hate those rudes surprises). I understand Novak Enterprises sells a pretty good master overhaul kit also.
80cj is offline
Grinding noise while starting. Help Please. sundownbrown Jeep CJ Forum 6 06-14-2009 09:55 PM
Starter Problem - grinding noise TKFireman Jeep CJ Forum 4 05-10-2009 07:35 PM
Grinding Noise in reverse CompGuru Jeep CJ Forum 19 10-31-2007 09:39 PM
grinding noise 83 cj-7 258 Jeep CJ Forum 11 01-03-2005 07:22 AM
grinding noise jeepster18_88 Jeep CJ Forum 1 02-27-2002 02:59 PM
