Quantcast Need help with gears - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Need help with gears
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire Carrier
Old 11-24-2009, 10:04 AM   #1
wertyu78
I have an 86 CJ7 with the TF99 Dana 300 and dana 44 rear end.
I have 35 inch tires on it and have not regeared. Acceleration is poor, as well as gas mileage.
What do i need to do to regear?
wertyu78 is offline   Reply With Quote
Old 11-24-2009, 10:14 AM   #2
buzzbrick
If you search 're-gear' you'll get all you need to know; this subject comes up a lot. Chances are good that if you have to ask, you'll probably (almost guaranteedly) want to just have a shop do it. There's lots of ways to mess this one up and completely trash your gears.
As for a quick summary of needed parts:
-gears (in your case likely 4.56 or 4.88)
-carriers (you'll need both front and rear axle)
-gear install kits
-diff cover gaskets
-silicone RTV
-gear oil
Originally Posted by Rob99 View Post
It can't be a scam. There's pictures of Asian people in business suits pointing at charts and graphs.
buzzbrick is offline   Reply With Quote
Old 11-24-2009, 10:48 AM   #3
curbcrawler
1946 CJ2A
I ran the exact set up, year, tanny, tire size, the rare for that year d44 rear end, every thing you have. I used 4: 11 gearing that helped alot but on the highway 70mph I was at 2800 on the tach. Any lower gearing 4.56 or lower would make your engine scream at high way speeds assuming its a i6 258. If you dont go hwy speeds go with 4.56 or lower. I fixed my problem by installing a 5 speed manual tranny.
1946 jeep cj2a- chevy 350, holly carb 600cfm, edlebrock intake, sm465 tranny with dana 300 transfer case, dual flowmaster exhaust, dana 30 axle up front, amc 20 in rear, 31" bfg all terrain tires
1986 jeep cj7 weber carb, comp cam rv cam, borla header and cat-back system, rancho 1.5 suspension lift, detroit trutrac limited slip, 35" bfg all terrains, Team Rushed, rock crawler bumpers in front and back.
curbcrawler is offline   Reply With Quote
Old 11-24-2009, 11:19 AM   #4
CJATE
CJATE's Avatar
i am very happy with my 4.56 on 35's at times wish was lower, but I would not do 4.10's
mine is fine on the highway (but i try not to put it there)
83 CJ-8 scrambler
SOA
Locked and Twin-sticked
35's, fenders cut
4.56
bad paint
leaks just about everything
CJATE is offline   Reply With Quote
Old 11-24-2009, 01:13 PM   #5
80cj
80cj's Avatar
1980 CJ5
The OP has an auto tranny. 4.10 gears may be sufficient considering that the auto tranny's torque converter will help getting started from a dead stop or on hills and still yield decent gas mileage and highway RPM.
80cj is offline   Reply With Quote
Old 11-25-2009, 10:11 AM   #6
curbcrawler
1946 CJ2A
My thoughts and experience exactly. the only time I wanted for more gearing was in loose sand then I would just shift the transfer case into low range. I swapped in a manual 5 speed eventually, to get more on the top end. 70mph at 3000 rpm was killing my gas milage not to mention the i6 does not like high rpms.
Old 11-25-2009, 11:02 AM   #7
80cj
80cj's Avatar
1980 CJ5
Another thought is that there is a 4.27 ratio available for the D30 and D44. This could be a good compromise for 35's.
Old 11-25-2009, 11:09 AM   #8
80cj
80cj's Avatar
1980 CJ5
Hmmm curbcrawler... did you correct your speedo? According to this chart, 2800 seems a bit fast. Although the chart is set for 65 mph, 5 mph more should not result in the 2800 rpm you saw.
4Lo.com :: Gear Ratio & Tire Size Chart
Old 11-26-2009, 01:32 AM   #9
curbcrawler
1946 CJ2A
I used a GPS. 2800 is exactly what I got at 70 mph. In review of my specs. I conscidered the true diameter of my tire, I run 35"BFG ATs which measure out at 33-34" in diameter not 35" as claimed by the manufacturer, that could account for extra rpms. According to the chart he would have be at 28oo and some with a true 35" tire at 65. Still, not real great.
Old 11-26-2009, 09:12 AM   #10
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
That chart is off. I have a GPS also and use measured 'mile' markers so know my speedometer is right on.
At 65 mph, I am turning 2300+ rpm with 33" tires, 3.31 gears and 1:1 tranny gear. The chart says I should be turning 2191 rpm. Hmm unless my tires are actually 32. Ok, nevermind....
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Old 11-26-2009, 12:22 PM   #11
80cj
80cj's Avatar
1980 CJ5
I did some calulations using the rotational velocity formula at this web site:Gear Design Equations Formulas Calculator Velocity Speed MPH
The rotational velocity (engine RPM) for a true 35" tire at 70 MPH would be 2755 RPM. Considering that your 35's are a little less than 35" true diameter, it looks like your 2800 RPM figure is in a very close ball park.
Old 11-26-2009, 05:11 PM   #12
curbcrawler
1946 CJ2A
Glock Forum
