need help drive shaft dropped - JeepForum.com
post #1 of 5 Old 10-23-2009, 07:55 AM Thread Starter
Viencent
1982 CJ7
Ok I can use a little help, on the way to work this morning the back end of my drive shaft dropped out, from what I can see one of the brackets holding the
u-joint to the rear end came loose, didnt see any other damage, how hard will it be to replace the joint with a new one? and what tools and parts will I need?
Im not much of a machanic but can turna wench if I know what needs to be done.. Thanks for any help
Viencent is offline
post #2 of 5 Old 10-23-2009, 08:25 AM
Mike Romain
A book like the CJ Haynes manual is a good one for these kinds of fixes. It goes over the tools and methods.
I use an old 3/4" I think it is socket to pound out the old joint and tap the new one in. There are circle clips that have to be pried out, I use a special pair of pliers for this or two mini screwdrivers.
Penetrating oil can help a Lot!
When you get the new joint, I recommend you also get new straps and bolts, they are cheap and the old straps will likely be stretched too bad to hold any more.
I also prefer the joints that can be greased, the non grease ones fail far too fast due to water contamination on the swampy trails I run on so they are basic garbage.
Mike
Mike Romain is offline
post #3 of 5 Old 10-23-2009, 09:04 AM Thread Starter
Viencent
1982 CJ7
Thanks for the advise, lol forgot I have a Haynes manual will read it now
Viencent is offline
post #4 of 5 Old 10-23-2009, 10:31 AM Thread Starter
Viencent
1982 CJ7
ok problem fixed,a friend from work fixed it on the spot, took him about 45 minutes and cost me $15 for the joint and breakfast for the 2 of us
Viencent is offline
post #5 of 5 Old 10-23-2009, 10:34 AM
Southtowns27
1955 CJ5
Nice. Check the bolts for tightness again in a few days. Probably wouldn't hurt to check the front driveshaft as well.
Southtowns27 is offline
Grand Cherokee Drive shaft/CV Shaft jollyroger Jeep CJ Forum 5 12-13-2011 05:31 PM
New Drive Shaft HELP Joe_CJ5 Jeep CJ Forum 2 01-12-2009 10:55 PM
drive shaft? bulljeeper Jeep CJ Forum 20 02-01-2007 08:28 PM
Drive Shaft :-( bruced Jeep CJ Forum 2 09-18-2005 08:34 PM
drive shaft :( thenubsterman Jeep CJ Forum 3 03-01-2005 03:50 PM
