Need Help Diagnosing a Vibration in 85 CJ - JeepForum.com
post #1 of 6 Old 07-11-2016, 08:15 PM Thread Starter
mb_24
Have a new vibration that appeared out of no where the other day. Feels like I'm riding on knobby mud tires. Vibration starts at 35 mph. Goes away when I push in the clutch at speed. Vibration not there if I rev it with clutch pulls in while rolling at 35+ mph. Feels like it's coming from the back.
Pulled the rear tires. All good there. Swapped in the spare on both sides...still there.
Thought it might be the rear diff. But since it goes any when I push the couch and the driveshaft still spins, I don't think it's that.
Checked the FSR and didn't see anything definitive.
What do you guys think?
1985 CJ-7 Renegade, Sebring Red, 258 + 5-speed
mb_24 is offline
post #2 of 6 Old 07-11-2016, 08:29 PM
only in a jeep cj
Could still be the rear axle or rear driveshaft even though it goes away with clutch pedal in because all that does is take the load or strain off the joints and parts. Think as the parts free spinning
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 6 Old 07-12-2016, 09:39 AM
twistedskipper
Sounds like the typical worn U-joint vibration.
Steep or incorrect drive line angles can also cause this, but it doesn't sound like you changed anything that would cause that to appear.
twistedskipper is offline
post #4 of 6 Old 07-12-2016, 08:17 PM Thread Starter
mb_24
Thank you gents....the winner is...u-joint. The one cap was fried and the needle bearing burnt out.
Replaced it and she rides like butter.
Appreciate the help!
mb_24 is offline
post #5 of 6 Old 07-13-2016, 09:05 AM
LumpyGrits
Cj
Make sure the DS is 'phased' correctly as far as U-joint position.
Also check for worn slip spline.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #6 of 6 Old 07-13-2016, 06:54 PM
258
Damn, nothing like the easier fix. NICE!
258 is online now
