Need help with a CJ7 brake issue please - JeepForum.com
post #1 of 2 Old 07-17-2012, 09:07 PM Thread Starter
Dukethedog
My CJ does something strange. When it is hot out, and I do a lot of stop and starting in heavy traffic, the brakes start to grab a bit. Normally when cold, the jeep rolls easily at a light or down a slight incline. Once this issues starts to happen, you can feel the jeep come to a stop and not want to roll. If
i take my right foot and set it behind the brake pedal and pull it out hard (I can feel it pull out a bit) then the jeep will free roll again.
So what is binding up that requires me to pull the brake level of after every stop in heat. Finally, when in this mode the brake light also stays on after you release the pedal, so park of my parking ritual is to reach in with m hand and pull the brake pedal out fully.
Any wisdom? Love to get this fixed!
Thanks
Dukethedog is offline
post #2 of 2 Old 07-17-2012, 09:41 PM
letchcore
1983 CJ7
I say the rear drums are adjusted too tight. Heat expands things. Maybe its tightening up your brakes enough to make them rub.
83' CJ7 "Strokie" Patriot blue, 4.6L, NSG370, D300, 4.56 gears, ARB's, Warn FF kit, OME Springs, 35in Kevlars.
83' CJ8 GM Torch red. 2.5in SkyJacker lift. Very stock.
83' CJ7 Slate Blue Met. 49k miles
04 Wrangler Rubicon. Stock
letchcore is offline
brakes , cj7
Brake issue CrazyHorse6 Jeep CJ Forum 2 05-13-2012 07:24 PM
69 cj5 brake issue challieboy27 Jeep CJ Forum 0 03-14-2011 10:42 AM
brake issue jeepcj7304 Jeep CJ Forum 0 04-13-2010 12:53 PM
Another brake issue. 78treehugger Jeep CJ Forum 9 08-03-2009 12:07 PM
e-brake issue jslchap Jeep CJ Forum 8 09-05-2008 09:28 PM
