need help with amc 20 axle - JeepForum.com
post #1 of 5 Old 05-23-2003, 09:18 PM Thread Starter
richard-2003
well, I've got my jeep down to the frame now. Where I could start to build up. I've decided to start with the rear axle. Which is a amc model 20. Iwas planning to put a one peice Mosser in it; but my question? Has anybody have any problems with getting the flange and axles shaft out. I've tryed what the repair manuls say and the damn still won't move. Does anyone know away of removing this??? Thanks
richard-2003 is offline
post #2 of 5 Old 05-23-2003, 10:14 PM
only in a jeep cj
Are you having trouble getting the flange off the shaft or the axle shaft out of the housing end? Without the large 3 arm puller, it's very hard, but can be done.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 5 Old 05-23-2003, 10:46 PM Thread Starter
richard-2003
the flange i used the 3 arm puller and it ended up dig into hole of the axle shaft.. thanks
post #4 of 5 Old 05-24-2003, 10:31 AM
rustyCJ
i was told once to put the puller on and get it nice and tight, then to take a torch and heat the flange. this expands it and makes it pull off the shaft easier. cant say if this works or not cause i havent tried it but it makes sense.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #5 of 5 Old 05-25-2003, 07:41 PM
CoryB
CoryB's Avatar
2015 JK Wrangler
If you're replacing the axleshafts, don't worry about trying to remove the flange.
Pull the whole axle out and then drill/dremel/crack the bearing retainer and bearing off. That way you can get the brake backing plate.
You need a BIG honkin' puller in conjunction with a BFH (Big Friendly Hammer) to remove the flange anyway. Unless you thrive on frustration , don't fool with it.
CoryB is offline
amc20 one piece axle turns axle to open diff? 84cj7jd Jeep CJ Forum 6 04-08-2009 10:23 AM
84 CJ-7 Axle Help for a Axle Newbie MikeScott Jeep CJ Forum 0 09-16-2008 10:57 PM
Changing my AMC 20 rear axle....and if I used a Land Rover series III axle? Frankcr Jeep CJ Forum 0 09-15-2007 02:13 PM
Narrowtrack rear axle with 2" spacers match up with a widetrack front axle? Blthomas Jeep CJ Forum 1 05-11-2007 09:25 PM
