Need help on amc 20 - JeepForum.com
post #1 of 2 Old 08-10-2002, 11:22 PM Thread Starter
Bryan L.
Need help on amc 20
Brake drum is rubbing dust cover, Do I shim out or in? 1984 CJ-7
Bryan L. is offline
post #2 of 2 Old 08-11-2002, 01:32 AM
80cj
80cj's Avatar
1980 CJ5
I take it you mean the drum is rubbing against the backing plate? In that case maybe the thing to do is to add shims then remove shims from the opposite wheel. The motion is transfered between axles through the differential spacer block. Something must be really worn if that is happening.
80cj is online now
