Quantcast Need help adjusting 2BBL Carb - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Need help adjusting 2BBL Carb
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 08-30-2009, 03:23 PM   #1
theplasterman
1983 CJ8
The carb in my 85 CJ7 needs some adjustment but I don't know where to start. When I first start the jeep and it is at high idle it is working fine. After a couple of minutes and the idle calms down is when the carb sputters and stalls out unless I keep giving it gas. My knowledge of carburetors is limited. Any help would be appreciated.
85 Cj7 258 inline with 3Spd Auto
theplasterman is offline   Reply With Quote
Old 08-30-2009, 03:26 PM   #2
Bubba Ray
Do you what carb you have? A pic might help.
Bubba Ray is offline   Reply With Quote
Old 08-30-2009, 03:26 PM   #3
mwhanson
1967 CJ5
May need more than ajusting...you may need a rebuild kit for it...only cost around $20-$30 to buy it...if it's the original carb it may be time...usually the rebuild kit gives you the adjustments also...
mwhanson is offline   Reply With Quote
Old 08-30-2009, 03:32 PM   #4
theplasterman
1983 CJ8
What is included in rebuild kits? I purchased one but it only has risers, gaskets and a needle in it. Is there a hards part rebuild or will that do it?
[COLOR="Red"][CENTER][SIZE="4"]I THINK I'M ADDICTED[/SIZE][/CENTER][/COLOR]
(SOLD)2011 JK Unlimited - Rugged Ridge Stubby, smittybilt 10k Synthetic, Tuffy Concealed Carry Drawer, Tuffy Security Deck.
Old 08-30-2009, 03:36 PM   #5
a2tripp
mine did the same, after days of fixing vacuum leaks I decided to rebuild the carb and bore out the idle tubes. Runs like new now, and I too had limited knowledge on carbs. Search the forums, i got all my info here. hope this helps
04 tj, nothing special
a2tripp is offline   Reply With Quote
Old 08-30-2009, 03:38 PM   #6
mwhanson
1967 CJ5
Should also have the accelerator pump/diaphram, gaskets, jets...doesn't look like much but makes a difference. I had the same problem with my 67 CJ with a 225 V6...probably the accel pump is the problem...the rubber ring usually breaks down over time...
Old 08-30-2009, 03:39 PM   #7
mwhanson
1967 CJ5
Forgot about looking for vaccuum leaks...that's another big one...
Glock Forum
