Need help with 84 CJ7 vacuum hoses!!!! - JeepForum.com
post #1 of 107 Old 12-03-2012, 05:59 PM Thread Starter
Chuggins08
I am trying to get my 258 4.2L amc engine to run, and the first to tackle are the vacuum hoses and where their correct locations are. When I got the jeep there were zero hoses hooked up, so thought that maybe hooking the hoses up correctly could be vital in this rebuild. Anyone have any diagrams/photos/videos that point me towards the right path. Suggestions and advice are appreciated.
IMG00242-20121203-1937.jpg   IMG00243-20121203-1938.jpg   IMG00244-20121203-1939.jpg   IMG00245-20121203-1940.jpg
1984 Jeep CJ7
258 4.2L Inline 6
Motorcraft 2150 Carburetor
Chuggins08 is offline
post #2 of 107 Old 12-03-2012, 06:25 PM
spward
Does this work?
Scott
spward is offline
post #3 of 107 Old 12-03-2012, 08:06 PM Thread Starter
Chuggins08
yes that is awesome, i really appreciate it. Could these vacuum hoses not being hooked up effect the engine not running?
1984 Jeep CJ7
258 4.2L Inline 6
post #4 of 107 Old 12-03-2012, 09:50 PM
spward
Honestly, i don't know about a complete shutdown. Think of it this way, you need fuel, air and ignition for it to run. I would think wrong hoses could be a concern. I am still it teardown mode and most everything was working when I started a few months ago.
Scott
spward is offline
post #5 of 107 Old 12-04-2012, 12:46 AM
BagusJeep
1981 CJ7
HAve a good look at what you hav ether ebefore you assume it will all just hook up and run properly.
What are the laws like in your State, do you need to get it back to original?
I would then look at the following:
What carb have you got? It does not look like a Certer BBD with a stepper motor so some of thet emissions equipment will never work unless you get one.
What air filter have you got? Some of that hooks up to the TAC. No TAC = No hoses to attach
What exhaust headers are you running? I cannot see clearly if you have the original cast headers. If you have tubular then that EGR valve is not going to work.
Do you have a brake booster? Sorry, photo is blurred and I cannot see it.
Some of the kit in the diagram posted above would be fine and dandy to have, like the Forward Delay etc but how many of those bits have you got?
If you want to see if it can run properly you only need 2 hoses, one between the distributor and carb and one from the manifold to the brake booster (if you have one). I would then stopper every other port in the carb and manifold. The port on the carb for the distributor can be ported or manifold vacuum, you need to work out what they are. Basically manifold sucks at idle, ported only higher up. Manifold may make it run better. Once it i srunning straight you could look at the PCV hose and hooking up the vacuum canister to purge various emissions etc etc
If you have the computer controlled type Motorcraft DUraspark ignition just see if it is nuttered. Basically the sensor wires from the distributor should go to the ICM and not up into the dash area to the computer.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 107 Old 12-04-2012, 05:35 AM Thread Starter
Chuggins08
Yeah me and two guys I know that work on jeeps were thinking it wasnt the original carb, but we cannot seem to find a brand name or anything. The PO put an edlebrock (or however u spell it) air filter on it. It does not have a brake booster either. And by the way, I live in georgia so we dont have smog tests done or anything. Im thinking the headers are original because they are more square than tubular.
1984 Jeep CJ7
258 4.2L Inline 6
post #7 of 107 Old 12-04-2012, 05:46 AM
waterdowg
Looks like a MC2100 carb. If you going to keep the carb and not worry about all the emissions stuff do the nutter bypass. These diagrams should help witht the vacuum lines. They are both the same except one if for 2 port cto the other ia 5 port cto. Yes, if the vacuum lines are not hook up or not hook up at all the engine may not run or may not idle or run correctly.
waterdowg is offline
post #8 of 107 Old 12-04-2012, 06:46 AM Thread Starter
Chuggins08
how do I go about doing the nutter bypass?
1984 Jeep CJ7
258 4.2L Inline 6
post #9 of 107 Old 12-04-2012, 06:55 AM
waterdowg
Do search on this site ot do a google search you will find tons of stuff. But basiclly you are bypassing the computer between the Ignition Control Modual(ICM) to the distributor. You run 2 wires from the ICM to the distributor. Then you set the timing to 8* BTC. Its really easy, and puts the Jeep back to the pre computer era.
post #10 of 107 Old 12-04-2012, 07:46 AM
waterdowg
Here you go. http://www.jeepforum.com/forum/f8/ho...bypass-522262/ You will not need to worry about the stepper motor part. You do not have that on your carb. That was only the original Carter BBD
post #11 of 107 Old 12-04-2012, 01:22 PM Thread Starter
Chuggins08
I cannot find the orange and purple wire that are supposed to be going to the ignition module...
1984 Jeep CJ7
258 4.2L Inline 6
post #12 of 107 Old 12-04-2012, 01:33 PM Thread Starter
Chuggins08
nevermind I found it. So just tie in from orange and purple from distributer to orange and purple from ignition module, then hook up vacuum hoses like the diagram above?
1984 Jeep CJ7
258 4.2L Inline 6
post #13 of 107 Old 12-04-2012, 05:49 PM
waterdowg
Yes you will have to cut the wires. Make sure you twist the new purple and orange wire. I used a drill I put one end of each in a vise the other ends in drill and twisted the wires. It is very important that its done.
post #14 of 107 Old 12-04-2012, 05:54 PM Thread Starter
Chuggins08
ok, i have a guy coming over to help me with the vacuum hoses first, we are going to see if we can get it back to like when it was stock. But if that goes down hill, then we will be doing the bypass.
1984 Jeep CJ7
258 4.2L Inline 6
post #15 of 107 Old 12-05-2012, 01:32 AM
BagusJeep
1981 CJ7
If you have the original exhaust headers they connect to the bottom of the inlet manifold, there is a gasket etc. If they are not connected the EGR valve has nothing to do as it has no Exhaust Gases to Recirculate.
Good luck with sorting out all that spaghetti, I suggest getting hold of the Factory Service Manual which has a whole section on the emissions control.
258 , cj , cj7 , inline 6 , jeep
