Need Fuse Box Diagram/Layout (under dash) - JeepForum.com
post #1 of 4 Old 10-04-2008, 08:11 PM Thread Starter
adkmtnguy
1997 XJ Cherokee
Hello everyone,
I'm brand new here, my girlfriend just got a 1984 CJ7 and we are looking for a Fuse Box Diagram or layout. The headlights won't work. There are no other problems with our Jeep! It runs great and there are no forseeable problems in the future. We got LUCKY!
I have been searching online for this for a couple hours now and need to get to other things. I hope someone might be able to send me a diagram or lead me a link that works.
Thank you for your time.
~ADKMtnGuy
adkmtnguy is offline
post #2 of 4 Old 10-04-2008, 09:18 PM
79BlackPearl
1979 CJ7
Give this a try.
http://www.geocities.com/jeep_resour...fuse_panel.jpg
Also, at any local auto parts store you can pick up a Haynes or Chilton manual that is a good starter guide to repairs on your Jeep.
Also, welcome to the JF. There is a wealth of information on here. Learn to use the "search" feature at the top of the screen.
And just in case someone hasn't told you, and even though you a CJ that is apparently in good shape......J.E.E.P. = Just Empty Every Pocket.
To try some fixes, pull each fuse, one by one and check them. Next check your light switch, it might actually be bad. Are the bulbs bad. Do the other "parking lamps" work when the headlights are turned on.
Welcome and have fun out there!
79BlackPearl
79 CJ7, 3" Lift, 360 V8, Edelbrock Performer Intake, Comp Cam, Holley 650 Truck Avenger, Hedman Headers, Moser Axles, Herculiner, Warn M8000i, 33" Timberlines
Guaranteed to Make $$$$ with your Computer! No Risk Involved! Simply press shift-4 four times in a row.
79BlackPearl is offline
post #3 of 4 Old 10-05-2008, 04:11 AM
John Strenk
John Strenk's Avatar
1976 CJ5
TO make thing easier, there is no fuse in the fuse box for the headlight. It's a circuit breaker inside the headlight switch. The most common probblem with headlights is the dimmer switch on the floor. When this goes bad, you might onlyy get high beams or no lights at all.
John Strenk is offline
post #4 of 4 Old 10-05-2008, 02:38 PM
Mike Romain
I will second the dimmer switch being the most common failure. The aftermarket switches are pure garbage.
If that isn't it, the fuse link is located on the fender solenoid, where the battery cable connects to it. You will find a few 8" or so pieces of wire with fat rubber tube connectors where they join the harness pieces.
Usually when the breaker goes, the headlights flash on and off.
Mike
Mike Romain is offline
1978 Fuse Box Diagram CaptKirk Jeep CJ Forum 1 12-29-2009 07:16 AM
Gauge Layout for Custom Dash asoude1 Jeep CJ Forum 8 03-17-2009 11:25 AM
Anyone got a pic or diagram of glass fuse box? PortlandCJ76 Jeep CJ Forum 1 06-09-2007 01:47 PM
77 CJ5 Dash Layout likityoung Jeep CJ Forum 3 03-16-2005 12:57 AM
fuse box diagram derm Jeep CJ Forum 5 10-05-2002 03:09 PM
