need fix for spring hanger - JeepForum.com
post #1 of 3 Old 09-24-2002, 07:50 AM Thread Starter
CJMONEYPIT
Question need fix for spring hanger
The welds holding the nuts onto the inside of the frame rail have broken on the driver's side rear spring hanger of my 83 Scrambler. The bolts just spin freely with a significant amount of play in the entire assembly. I would love to replace the stock hangers, but can't get at the nuts to put the new hangers on. (don't really want to weld the new ones on). There is a cross member that runs through the frame rail and a body mount perch that just wont let me get at them. Anyone know of a trick fix for this? This is the only thing that's keeping her from her maiden voyage off road.
CJMONEYPIT is offline
post #2 of 3 Old 09-24-2002, 08:48 AM
CSP
Sounds like you can't get the old bolts out. Grind the heads off the remove the bolts and get the shackle hangers off. If what's left of the bolt and nut inside the frame come loose and are now hopelessly lost inside that frame that's ok. It's actually what you want. If the'yre not fee either knock them loose with a punch or drill them out. Next look for a hole in the frame somewhere close by that a nut of the right size would fit through. You'll need what's called a "flange nut" which is like any other nut except one side of it has serrations or teeth that will grab onto the surface it's being bolted to in order to prevent spinning. Now feed a small wire into the frame at the shackle hanger bolt hole and out the hole that a nut will fit through. Attach the frame nut to the wire and pull it back to the hole for the hanger. Just attach it so that it will hold on while you're fishing it through the frame, but loose enough that you can remove the fish wire once the nut is at its destination. Now attach the shackle hanger to this nut carefully with a new bolt with plenty of anti-sieze on it.
Hopefully this makes sense and helps. It sure beats cutting a slot in the frame to fit a new nut in there.
Here's what a flange nut looks like:
CSP is offline
post #3 of 3 Old 09-24-2002, 11:06 AM
Bulletproofcj7
Hey! I like that wire trick! it sure beets the magnet on a stick method!
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
Do I need to replace the spring hanger? 1984Laredo Jeep CJ Forum 2 11-25-2009 09:09 PM
cant get spring hanger bushings out caleb7mm Jeep CJ Forum 6 05-24-2009 07:36 AM
Measurement Request: Spring hanger to shackle hanger DT5150 Jeep CJ Forum 5 05-08-2009 07:01 AM
Rear Spring hanger 78treehugger Jeep CJ Forum 3 04-07-2009 06:14 PM
Help Me With Spring Hanger! Jack-Jack Jeep CJ Forum 5 10-02-2005 06:45 AM
